How do I get Dr Prius?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KJ Fitz, Jul 21, 2021.
  1. KJ Fitz
    KJ Fitz Junior Member
    55
    Guam
    Pulled the hybrid battery, all cells checked above 7.5 volts, cleaned up a lot of corrosion from cables, replaced bus bars, put battery back -- still have The Red triangle of Death. Apparently someone is low capacity.
    At least now it will start, and is sending power to the hybrid battery, but still have the Red Triangle. I understand there exists a "Dr Prius" app which with a Bluetooth OBD scanner, will tell me what's up with the cells. How do I get that app? The techstream is not an option, as I don't have a laptop.
    Code is P0AFA, Hybrid Battery Voltage Low, per my OBD scanner.
    #1 KJ Fitz, Jul 21, 2021
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,489
    6,575
    Texas Hill Country
    You download dr prius from the app store. You need a bluetooth obd2 reader. If your car drives at normal speeds try driving it until it charges the battery. Just cleaning the corrosion won't charge it.
    jerrymildred likes this.
  3. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    It still has the Red Triangle of Death and will not drive. Unlike before I cleaned it up, though, it now starts the ICE and charges the battery, which has gone from one purple bar to six blue bars. I'll download the app and try to find a Bluetooth compatible OBD2, thanks -- but they seem to be sold out everywhere. If anyone has a link to one that's actually available, I'd appreciate it.
    QUOTE="rjparker, post: 3171064, member: 41651"]You download dr prius from the app store. You need a bluetooth obd2 reader. If your car drives at normal speeds try driving it until it charges the battery. Just cleaning the corrosion won't charge it.
    [/QUOTE]
  4. rjparker
    10,489
    6,575
    Texas Hill Country
    I am showing the Amazon link as available, maybe not two day to Guam.
  5. BuildingInspectorBrian
    BuildingInspectorBrian Junior Member
    32
    Tacoma
  6. bisco
    52,371
    Call his office and make an appointment.
    Be sure to bring your insurance card
