How do I go about buying steel wheels for my snow tires?
Discussion in 'Gen 2 Prius Main Forum' started by yossi, Feb 10, 2022.
  1. yossi
    yossi Junior Member
    61
    I am getting snow tires and looking to get steel wheels so I can easily swap them. I have the 2008 base, so its 185 65 15, but I am not even sure where to look for used wheels, or even how I confirm the fit - is it just any 15's is there also a bolt pattern, plus diameter I need to look at?
  2. alftoy
    alftoy Senior Member
    1,132
    507
    Saskatchewan, Canada
    TireRack.com will show wheel sizes and offsets, or google 2008 Prius 15" steel rims. Lots of links many to Priuschat.com. New steel rims probably $90.
    Looks like you're in Indiana, try veldmans.
    #2 alftoy, Feb 10, 2022
  3. PriusCamper
    PriusCamper Senior Member
    10,932
    4,430
    Pacific Northwest, USA
    Junk yard...
    Rmay635703 likes this.
  4. Mendel Leisk
    38,260
    I used an older Corolla rim, 15” black steel. Fits hub perfectly. Can dig up the part no when back home.
    Tideland Prius likes this.
  5. PriusCamper
    10,932
    4,430
    Old Toyota Celica wheels work too... Also Toyota Scion vehicles have wheels that fit...
  6. xliderider
    xliderider Senior Member
    7,849
    3,103
    Honolulu, HI
    Add to the list Toyota Matrix/Pontiac Vibe wheels, they have the 5x100 bolt pattern and appropriate backspacing.
  7. Aegean
    Aegean Active Member
    423
    184
    Alexandria VA
    I used Volkswagen Jetta steel wheels with hub centric rings and matching lugs.
  8. Stevewoods
    Stevewoods Senior Member
    647
    983
    Seattle, WA
    I went to my local tire store. Sort of know the owner. He sold me a used set of snow tires on alloy wheels. It turned out much cheaper than Tire Rack. And the alloy wheels make me look "cool." :p:D:p
    My other option was buying used wheels on Craigslist, which I nearly did....lots of good deals (it seemed), but deciding to check the local store was a good idea.
    Don't know if you do Costco, but might be worth a call.....a membership is $60....
    The used set was a nice set actually and the snow tires were nearly new. Price out the door was $600. TPMS would have been an extra $200, but since he was not putting them on the vehicle he said he was not legally obligated to insist on TPMS.
  9. Rmay635703
    Rmay635703 Senior Member
    2,580
    1,601
    Somewhere in Wisconsin
    2013 Chevy Volt
    There are many cars old and new with the proper lug pattern
    My snows are on $25 a rim steelies
  10. PriusCamper
    10,932
    4,430
    PS: To clarify, lug pattern is 5 bolts equally spaced 100mm apart...
  11. Mendel Leisk
    38,260
    Here's the info for mine, works on a 2010 Prius:
    15" black steel rims p/nCorolla: 42611-02471
    With lug nuts p/n: 90942-01007 (utilitarian, open-ended, galvanized)
  12. jrw1621
    jrw1621 Junior Member
    Huron, OH
    Here's a place to check: http://www.car-part.com
    It is a website used by junkyards to list the parts and used/searched by customers like body shops. Put in your make model, year and zip code. Then enter the part your looking for; in this case wheel (with image.) Choose the alloy wheel just like your summer tires. The site will then list back to you full service junk yards that have the wheels with the closest ones to you first. Expect a genuine Prius 15" alloy wheel to cost $40. Even if the junk yard list them at a higher price, since your buying 4, don't be afraid to call them and offer them just $40 each. Prices are generally negotiable at junkyards.
    If you then come to a price agreement, drive to the junkyard and pick up the parts which will be waiting for you at the front counter.
    #12 jrw1621, Feb 13, 2022
  13. Mendel Leisk
    38,260
    Gen 3 alloys will work too, though centre caps are different (groove for jaw shifted). Maybe even 2nd alloys?
  14. alftoy
    1,132
    507
    Brand new Corolla Prius steel wheels on Craigslist
    15x 5.5 rims - auto parts - by owner - vehicle automotive sale
    Two 65R15 Snow Tires (Firestone Winterforce) on steel rims - auto...
    2 tires/rims from Toyota Prius C - auto wheels & tires - by owner -...
