How do I go about finding the right filter and oil for my Gen 2 Prius?
Discussion in 'Gen 2 Prius Main Forum' started by Joe Wall, Jun 27, 2020.
  1. ydpplqbd
    ydpplqbd Active Member
    551
    253
    Aftermarket Gen2 Oil Filter Part Numbers: STP S4967, Fram PH4967, Purolater L14476, Fram 4967,AC Delco PF1233, & Bosch 3311.*
    *- according to clerk at Autozone.
    Toyota Gen2 Oil Filter Part Number:
    90915-YZZF2
    #21 ydpplqbd, Jun 29, 2020
    ETC(SS) likes this.
  2. Mendel Leisk
    41,481
    Or just use a Toyota dealership with online parts sales, say McGeorge Toyota parts.
    ydpplqbd likes this.
  3. Joe Wall
    Joe Wall Member
    237
    51
    Wisconsin
    I got a free oil change actually. They found out that I need a new serpentine belt.
    I am not sure if it is the water pump or drive belt. Also need new brakes ASAP and gotta lookout for new tires.
  4. ETC(SS)
    7,165
    Um......
    OK.
    First thing's first.....how much did that 'free'oil change cost you?
    The belt goes for about $10 and it takes about 20 minutes (for me) to replace.
    A mechanic can do it in under 5.
    Don't mean to make you feel bad, but if you ever forget what kind of oil to put in your car, open the hood and look on top of the engine. Your oil filler cap might look like THIS:
    It does not matter what KIND of oil you get as long as it has the API "starburst" symbol and meets the standard for energy conserving (they mostly ALL do) but MOST IMPORTANTLY you need to have the right quantity of oil in your engine!
    And....in your case it should be 5w30........for now.
    @ydpplqbd very helpfully provided you with some filter options.
    The YouTubes will show you how and perhaps what tools you need.
    Learn About Motor Oil Standards : Motor Oil Matters: Motor Oil Matters
    Check your oil level as soon as you read this, and then every other time you fill up the tank.
    Consider NOT going to the dealership when you need brakes.
    Consider watching some YouTube videos for all of the common fluid and filter checks for your car and maybe spend $100 on some tools instead of another oil change.
    Good Luck!
    ydpplqbd and JerryScript like this.
  5. Joe Wall
    Joe Wall Member
    237
    51
    Wisconsin
    The brakes are very bad. Less than 1 mm and almost rubbing on metal. Tryig to figure out how to change these ASAP.
  6. Joe Wall
    Joe Wall Member
    237
    51
    Wisconsin
    They quoted me at $683 to replace the brakes, rotor, and serpentine belts (2). I'm gonna do them myself just gotta figure out replacing the brakes and etc.
  7. Joe Wall
    Joe Wall Member
    237
    51
    Wisconsin
  8. ETC(SS)
    7,165
    DIY is definitely cheaper than getting doinked over by the dealer, although to be honest I'd probably pay an independent mechanic to do the rears on the G2.
    I hear a lot of comments about cleaning and lubing the slider pins on the G2, so pay particular attention to that. I Haven't done brakes on this car myself so I can only relate what I've read over the years.
    Good Luck!!
  9. Mendel Leisk
    41,481
    Repair Manual info:
  10. JerryScript
    JerryScript Junior Member
    43
    38
    I could be wrong, but isn't there just one belt?
  11. Joe Wall
    Joe Wall Member
    237
    51
    Wisconsin
    Yeah I'm confused. Called another place and had one.
    I cannot get the wheel off after removing bolts any advice?
