How do I ground when taking power directly from battery
Discussion in 'Gen 3 Prius Technical Discussion' started by Taxi/Limo, Sep 22, 2016.
  1. Taxi/Limo
    Taxi/Limo Active Member
    526
    107
    I am going to run a hot battery wire to the drivers side to power two things
    Do I use the battery ground to do this or do I use just the energized wire and ground to the frame of the car?
    Thanks
    Nexus 6 ?
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Huh? Your positive, 12v wire from the red, positive battery terminal goes to the positive wires of your two devices.
    Then each device should have their own ground wire. You can ground them individually, or combine them and ground them together to an exposed frame bolt.
    Make sure each device has a fuse on the power (positive) wire.
  3. Taxi/Limo
    526
    107
    Forgive my ignorance does that mean I don't have to connect to the negative terminal on the battery ?
    Nexus 6 ?
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The Negative Post of the 12 volt battery just bolts to the frame in the rear. So the whole car is a 12 volt negative connection.
  5. Taxi/Limo
    526
    107
    Ok that makes sense
    Nexus 6 ?
