How do I install the Sigma EV Button?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by buffettjr, Jun 12, 2008.
  1. buffettjr
    buffettjr New Member
    Hi guys,
    I bought the official EV button off Sigma Automotive, and I have no clue how to install it. Can anyone help? I have a 2008 Prius. I've installed lockpick before with no problems, so I think I can handle it, I just need to know how!
    Any help would be appreciated.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,193
    Nixa, MO
  3. efusco
    19,891
    1,193
    Nixa, MO
  4. efusco
    19,891
    1,193
    Nixa, MO
    Here's Darell's "how to" for the connecting the OEM button to power it.
    Prius EV Mode
  5. buffettjr
    Thanks efusco,
    I had seen these links before, but I wasn't sure if they were apt. Will that PDF on installing a switch on a 2004 Prius work for installing the sigma button on a 2008?
    Thanks again.
  6. efusco
    19,891
    1,193
    Nixa, MO
    The basic install is identical for any sort of EV switch. You tap pin 14 and connect it to a momentary switch....you just bought a fancy momentary switch that happens to match the car.
    So yea, the first part of the install will be to tap pin 14 and run your wires over to the knock outs where the button goes just as in my original PDF.
    Next you need to reference Darell's web page for how to connect the button to the dimmer to get it to light up and to ground it.
