How do I know if my 2014 v vin has the updated rings?
Discussion in 'Prius v Technical Discussion' started by skydivetoday, Aug 1, 2021.
  1. bisco
    51,961
    New hycam coming with 18”
    hoping I can swap them for 16’s
    bolt coming with 17’s, not sure I have any options
  2. Mendel Leisk
    41,474
    They're harder on your back too. :(
  3. rjparker
    rjparker Tu Humilde Sirviente
    10,159
    6,316
    Texas Hill Country
    2014 Prius Rings and Pistons
    Tim Jones, Air_Boss and wr69 like this.
  4. wr69
    wr69 Member
    143
    79
    portland, or
    excellent diagram RJ. many thx for posting that! it is a bit more elaborate than the original TSB I saw and has the accommodation for the two mystery plants for each model-type. This somewhat deepens the plot though because those plants 0 and 1 unit numbers must not relate to each other. And that means Toyota would have made >1 million units total for that year (if each car gets unit 1 incrementally). So that high of a number also seems a bit improbable. did this document come from a newer TSB on the issue?
    Air_Boss likes this.
  5. rjparker
    10,159
    6,316
    Texas Hill Country
    I believe each model’s sequence number is cumulative over the years per plant. Otherwise they could not tell you which vin at a plant initiated a fix.
    Total Prii Per Type per Wiki
    Global cumulative Prius liftback sales reached the milestone 1 million vehicle mark in May 2008,[7] 2 million in September 2010,[8]and passed the 3 million mark in June 2013.[9] Cumulative sales of one million were achieved in the U.S. by early April 2011,[10] and Japan reached the 1 million mark in August 2011.[11] As of September 2022, the Prius ranked as the world's top selling hybrid car with 5 million units sold.[12]
    In 2011, Toyota expanded the Prius family to include the Prius v, an MPV, and the Prius c, a subcompact hatchback. The production version of the Prius plug-in hybrid was released in 2012. The second generation of the plug-in variant, the Prius Prime, was released in the U.S. in November 2016.[13] The Prime achieved the highest miles per gallon equivalent(MPGe) rating in all-electric mode of any vehicle rated by EPA with an internal combustion engine.[14][15] Global sales of the Prius c variant passed the one million mark during the first half of 2015.[16]
    The Prius family totaled global cumulative sales of 6.1 million units in January 2017, representing 61% of the 10 million hybrids sold worldwide by Toyota since 1997.[17]
    #25 rjparker, Aug 18, 2023
    Tim Jones and wr69 like this.
  6. wr69
    wr69 Member
    143
    79
    portland, or
    I can corroborate this above statement that unit numbers increment up each year from where they left off in a prior year, rather than start from zero. Based on an internet search, here is a 2015 VIN from a standard prius, which is currently listed on an internet site for sale:
    JTDKN3DU1F0420383
    F = 2015
    0 = the zero factory in japan
    420383 = unit number, cumulative from all prior years of prius builds at that factory.
    the reason I suspect this, is that from the above 2014 TSB advisory (starting the new rings/pistons):
    the VIN JTDKN3DU#E0358779 is a later 2014 VIN but is 358779, so that kinds of feeds into to a bit higher 2015 VIN of 420383, which is from the same factory "0".
    so once again RJ, thanks for this extra info! this was a great discussion and sharing of info!
