How do I leave 3rd gen in neutral after shutting off?
Discussion in 'Gen 3 Prius Technical Discussion' started by Priusprofit, Aug 14, 2018.
  1. Priusprofit
    Priusprofit Member
    96
    32
    Long island
    The 2nd gens have a fuse labeled "P CON MTR" that you can remove and the car will not shift into park when you shut it off.
    I need to find a way to perform the same for 3rd gen.
    I am replacing the headgasket and sending the head out to be rebuilt which will take about a week, in that time I will need to move the car and I can assume that something that I disconnect will prevent the car from going into accessories and going into neutral. Even if it doesn't I am still dying to know how to do this.
    52,863
    are you sure? i have never heard of it. i thought it was impossible to put a prius in neutral when off.
    Mendel Leisk and Raytheeagle like this.
  3. Priusprofit
    Priusprofit Member
    96
    32
    Long island
    Power on, select neutral, remove "P CON MTR" fuse, power off and the 2nd gen will stay in neutral.
    Then disconnect battery otherwise it will bark at you until the battery dies.
    I am searching far and wide for a way to do the same in a 3rd gen though!!!
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    There is an electrically operated pawl, that activates to emulate a Park mode. If not, it would remain in D. (which can cause electricity to flow while being moved)
    While I would not recommend it, you could spin the parking pawl motor while the Prius is off.
    Oddly, I can find Pics of Gen 2 and Gen 4, but not Gen 3, you are looking for a black circular piece on the transaxle like this Gen 4.
  5. ChapmanF
    19,033
    That sounds like a whole lot more fuss than the method the OP already knows, which is to disable the parking motor while the car is not in Park, and then shut the car off. Problem solved.
    I think the OP's original question was just about the easiest way to disable the motor, since in Gen 2 there is one fuse clearly labeled P CON MTR and maybe nothing in Gen 3 is labeled that way.
    A quick check of the wiring diagram would probably find the right fuse. Or just unplug the wiring at the motor (it's in a less unreachable spot in Gen 3), or at the imposingly-named Transmission Control ECU behind the glove box, which is nothing more than the controller for the parking motor.
    -Chap
  6. Priusprofit
    Priusprofit Member
    96
    32
    Long island
    Car is in the air where do I find this parking motor?
  7. Priusprofit
    Priusprofit Member
    96
    32
    Long island
  8. PriusCamper
    PriusCamper Senior Member
    13,467
    5,435
    Pacific Northwest, USA
    Isn't there an easy way to disconnect the park actuator? The wires aren't to deep into engine are they? Also if you unplug the hybrid safety plug and 12 volt battery when the car is pushed around in neutral, the tiny amount of electricity generated won't have anywhere to go, right?
  9. ChapmanF
    19,033
    There's a whole array of techniques in electrical engineering all devoted to not creating situations where "electricity generated won't have anywhere to go." The magnets in the MG1 and MG2 rotors are permanent (and strong!), so as they rotate, they will produce voltage in the windings, and the voltage, if high enough, will go somewhere. It won't care if it goes through parts of the inverter that it wasn't supposed to.
    I think in Gen 3 and Gen 4 the park motor is not too horribly hidden on the front of the tranny. But finding the fuse for it in the box under the hood is nicer if the car isn't raised.
    Physically removing the motor from the tranny isn't meant to be easy, as it is what serves as the theft-prevention device (you'll notice the steering column doesn't lock). The mounting bolts are in tamper-resistant collars. Doesn't stop resourceful thieves, but annoys them.
    -Chap
    PriusCamper likes this.
  10. PriusCamper
    13,467
    5,435
    This is super interesting/important info... But putting a partially dismantled car into neutral when you're in an auto shop and need to push it around isn't a design concern Toyota is unaware of, right? Surely they've planned for this scenario? I mean how could they not? Please suggest some ways OP can solve this....
  11. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Most repair shops have small dollies that can be placed under each wheel to allow moving a disabled car very easily. You can actually spin the car around if desired.
    jerrymildred likes this.
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Just what I was about to say. You only REALLY REALLY need them on the front, but all four wheel makes it even easier.
    And, if you're not using them often, they don't have to cost all that much:
    Vehicle Dollies - 2 Piece, 1500 Lb. Capacity
    Raytheeagle likes this.
  13. PriusCamper
    13,467
    5,435
    While that's the way they do it most often, it requires a very smooth surface and you have to have a pretty expensive shop to move a car from a work area to a parking area with no cracks or bumps... But I guess if you had a tow truck-type dolly... But again, I doubt the OP would ask for help if those options existed for 'em.
  14. ChapmanF
    19,033
    I suspect you can push nice-n-slow and not get into trouble. I would take the chance with mine if I needed to. I think the OP was mostly looking for how to defeat the park motor, just to make it possible to push the car.
    -Chap
  15. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
  16. ChapmanF
    19,033
    There appears to be a vacated fuse socket and a fuse lying next to it in that picture....
  17. PriusCamper
    13,467
    5,435
    Can you please explain what you mean buy "opening the fuse box" cover? They're just plastic covers, there's no circuitry involved in an open versus closed fuse box... #confused
  18. ChapmanF
    19,033
    While we were all bantering about other things, the original poster snuck back in with a "got it guys" post in #7.
    There's a photo in that post showing an open fuse box cover. It also shows one fuse removed; if I had to guess, I'd say that had more to do with inhibiting the parking motor than just the open-cover part.
    -Chap
    jerrymildred and PriusCamper like this.
