how do i program garage opener. can't find it anywhere
Discussion in 'Gen 2 Prius Main Forum' started by dsyoo86, Sep 22, 2007.
  1. dsyoo86
    dsyoo86 New Member
    16
    i have 05 prius package 2 and i don't kno how to use the garage programer. does it work for community gates too???? anyone help man .
  2. Tideland Prius
    16,155
    Umm, the instructions are fairly clear in the owner's manual (that's why you don't see any threads on it). There are two types - a regular remote and one that uses rolling codes. You have to determine which one you have and follow that set of instructions (or just pick one and if it doesn't work, follow the other set of instructions).
    If the community gates are operated by a remote, then you can also train the garage door opener to open the gates.
  3. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    It's on page 309 in the owners manual. But incase you're not the original owner and don't have the manual.....
    Erase the memory...hold down homelink buttons 1 & 3 for 20 seconds until the indicator light flashes.
    Decide which homelink button you want to program.
    Hold your garage door transmitter 1-2 inches away from the mirror.
    Simultaniously press and hold the garage door transmitter button along with the selected homelink button.
    DO NOT RELEASE UNTIL NEXT STEP COMPLETE>
    When the indicator light on the mirror changes from a slow to a rapid flash, you can release both buttons
    Test using the mirror button you just programmed. Remember, you need to press and hold the button a few moments, not just a quick push.
    If this doesn't work, advise and I will explain rolling code programming.
    A gate can be done in the same manner as above....using a different button on the mirror. While you are holding the selected mirror button, press and release repeatedly the gate transmitter button, until the mirror's indicated light goes from slow to rapid flash.
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
