How do I remove my shifter knob in 2007 prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Rose Sonnenberg, May 30, 2021.
  1. Rose Sonnenberg
    Rose Sonnenberg New Member
    Detroit Michigan
    I have a 2007 Prius I want to customize the interior. I found some cool replacement shifter knob tops. But I’m not sure how to get the factory knob out. I tried unscrewing it but it seems stuck. Any help would be appreciated. image.jpg
  2. Priusjames
    Priusjames Member
    92
    67
    Irvine, CA
    It just unscrews all the way off. At least, mine does.
    - cheers!
  3. Rose Sonnenberg
    Detroit Michigan
    So should I apply more pressure to get it off. It doesn’t seem to want to budge. I’m sure I could get some pliers with a good grip and get it off that way if it for sure screws out.
  4. Rose Sonnenberg
    Detroit Michigan
    Update. Got it off. It was on there though!!
    donbright and Priusjames like this.
  5. ChapmanF
    15,622
    They probably use a threadlock substance when they put it on. I think mine was like that.
    A trick: what I did with my replacement was I did not use anything like Loctite. Instead, I put a little dab of Plasti Dip on the threads and waited for it to dry. Then I screwed the knob on and it is nice and resistant to random turning and loosening, but it won't ever be glued on there like Loctite.
    Priusjames likes this.
