How do I remove Prius fog light assembly.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by '04Prius, Jan 27, 2013.
  1. '04Prius
    '04Prius Junior Member
    51
    Both of my fog lights are cracked and I have purchased new ones. How do I remove the old assembly? I have spent about 1.5 hours out there trying to figure it out and no luck. Please post pictures if possible.
  2. '04Prius
    51
    Help? Anyone?
  3. Unleashd
    Unleashd Junior Member
    71
    Oakhill, VA
    One way that I know of is to get the entire front bumper off to access to the wiring and specifically the 'tabs' that hold the two side pieces of the lower grille. Don't have actual pictures, but here are the relevant pages from the manual.
  4. CNCinCal
    CNCinCal Junior Member
    Gilroy, CA
    Unleashd: I'm working the same issue. Thanks for posting the manual section. Is it too much trouble to post sections LI-87 to LI-88? Also where can I get the PDF version of the manual. I looked on Ebay and all I could find were the paper versions. Thank you.
  5. Unleashd
    71
    Oakhill, VA
  6. CNCinCal
    Gilroy, CA
    Thanks Unleashd.
