How do I remove the center divider between the driver and passenger seat?
Discussion in 'Prius c Accessories and Modifications' started by Bryce Husserl, May 27, 2017.
Tags:
  1. Bryce Husserl
    Bryce Husserl Junior Member
    28
    27
    2016 Prius c
    There is a spare blank switch in my new prius, alongside the eco and ev mode buttons. I found a USB port that will fit perfectly and I want to install it, but I'm having trouble figuring out how to remove the center divider with the cup holders and shifting knob. I just want to remove the housing to run the wires. Sorry if the lingo and terminology isn't correct, i'm not a complete car guy. Thanks!
  2. djdawn
    djdawn Active Member
    255
    116
    Escondido, CA
    2014 Prius c
    The cup piece and the part that has the Eco button you just have pull up, those parts are held down with friction tabs. Not sure how to remove the shift assembly, but you can fish any cables you need under it pretty easily.
  3. Bryce Husserl
    28
    27
    2016 Prius c
    Thank you!
