How do I reprogram a computer to
Discussion in 'Gen 3 Prius Technical Discussion' started by douglasjre, May 17, 2018.
  1. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Just continue creating drag with mg1 when I let off the throttle
    52,821
    you don't.:)
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Why ?
    That's is pretty much what the B gearshift position is for.
    scona likes this.
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    The biggest issue is just reprogramming windows, it's not an open source code software like linux.
  5. sam spade 2
    7,035
    2,804
    2017 Prius c
    Wait.......what......are you saying that Toyota cars use Windows as their underlying operating system ???
    I certainly hope not.
  6. Prodigyplace
    12,711
    11,848
    Central Virginia
    Are they talking about engine Brake mode? You can do it manually but it ruins your fuel economy if you do that.
  7. douglasjre
    2,250
    751
    Null, NL
    I meant how do I program it to discontinue creating drag with the motor generator when I let off the gas
  8. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    What i just you may have noticed, is that if you badly state your desire, no one can solve your request.
    If you lightly apply the gas pedal, you can indeed get all the arrows to go away.
    Since no other car on the road behaves like what you request, Toyota's liability would be phenomenal. (as I understand your request)
    Prodigyplace likes this.
  9. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    Or just throw it in neutral.
    scona likes this.
  10. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Well he said "reprogram a computer", I figured he meant using a PC that's equipped with windows that's written with visual basic computer programming language, connected to the vehicle to perform the specific operation. And not the prius internal software.
  11. Prodigyplace
    12,711
    11,848
    Central Virginia
    Wow! Those are some assumptions!
    I program quite a bit, never use Visual Basic and rarely program for or on Windows.
    jerrymildred likes this.
  12. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Easy solution: You get a car that allows more regen (drag/braking) when lifting off the pedal. One pedal driving is really, really nice.
    The only "hacking" I've seen here is using Techstream and that's only changing factory settings but I guess that would be the place to start. Or maybe one of the phone/tablet apps.....
  13. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    From 1985 to 1988 I wrote for IBM PCs, in various languages, including IBM BASIC which was just re-branded QuickBASIC. Before, during. and after that, I wrote in RPG for the IBM S/36 (and once in COBOL). In 1992 I switched to SQL and PL/SQL on Oracle until 2002. (once a tiny bit of C, and once a trivial amount of ForTran, both on Unix)
    There is much to do that is not Visual Basic. The trick is using the right language for the right task. (bit manipulation in COBOL was not easy. Four lines of IBM BASIC became 260 lines of IBM COBOL)
  14. Prodigyplace
    12,711
    11,848
    Central Virginia
    Lately I seem to use php a lot either for web page applications or Linux shell scripts manipulating text data and using REST APIs.
  15. bisco
    52,821
    you can't.:)
  16. sam spade 2
    7,035
    2,804
    2017 Prius c
    Once again.....WHY do you want to do that ??
    Answer (again): You can't because it is re-charging the battery a little bit when it's doing that.
    If you insist on free-wheeling mode, you have to shift to Neutral.....or as mentioned, feather the gas pedal and watch the display, but there is NO good reason to do that.
  17. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    And again, if you DO succeed, every other driver who ever borrows your car will be at risk, as no other car does this.
    My younger brother once switched his front brake and clutch levers on his motocross bike, no one who ever rode a motorcycle before could adapt, they all crashed. Changing something so fundamental on your car will be similar, expect folks to rear end the car in front of them.
  18. Prodigyplace
    12,711
    11,848
    Central Virginia
    It also may well be illegal to drive such a modified vehicle on public roads.
  19. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Recomendation:
    Don't try to out think the engineers, designers and programmers of the Toyota HSD system.
    Just drive it.
    RRxing, Prodigyplace and Raytheeagle like this.
