How do I shut off abs alarm 2003 prius?
Discussion in 'Generation 1 Prius Discussion' started by jlawrencetorres, Feb 28, 2018.
Tags:
  1. jlawrencetorres
    jlawrencetorres New Member
    Los Angeles
    2003 Prius
    My abs light came on along with a constan alarm. I want to shut off the alarm, how do I do this?
  2. ChapmanF
    19,025
    You shut it off by fixing the problem. Do you have the trouble codes yet? If you don't have a scantool, you can search posts here for how to read the codes with a short length of wire and counting light blinks.
    -Chap
    Brian in Tucson and Mendel Leisk like this.
  3. Mendel Leisk
    42,349
    What do you mean by "alarm"? There's some sound emanating from the dash?
  4. jlawrencetorres
    Los Angeles
    2003 Prius
    Yea it's a constant alarm. From inside the cabin
  5. jlawrencetorres
    Los Angeles
    2003 Prius
    I appreciate you trying to help but your condescending tone at the beginning of your reply doesn't help. I know the problem already, I am fixing it on my next paycheck but in the interim I would like to disable this alarm. Any thoughts on how to do this?
  6. ChapmanF
    19,025
    Forgive me then; that wasn't clear in your first post. What is the problem, if I may ask?
    Clearing the trouble codes will probably do it, but only until the ECU detects the problem again. Beyond that, you could look in the wiring diagram for where the buzzer is....
    -Chap
    Brian in Tucson likes this.
  7. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    I didn't read Chap's tone a being condescending. The way to get the tone off is to do the repair.
    Chap is a good guy and an invaluable member of this forum. This is a pretty friendly forum, maybe the attitude problem is yours.
    When my brake booster pump went out, the tone came on. High pitched squeal. Pulling the aux battery strap would make it go off for a little while, but it came back soon.
    Mendel Leisk and Prodigyplace like this.
  8. jlawrencetorres
    Los Angeles
    2003 Prius
    Maybe you should read my response first before judging my attitude. I am not an idiot, i know that in order to get rid of the tone that the main thing to do would be to fix the problem. But that wasnt what i meant. I wanted to know any alternatives in the meantime to get it to shut off, i appreciate your help but i think youve misjudged me. Perhaps it is my fault i didnt specify, but theres no need to talk down to one another
  9. ChapmanF
    19,025
    Back in February you said you knew the problem; can you share what it is? Do you still have it?
    -Chap
  10. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    You can do that by disconnecting the buzz alarm by the driver side around the knee area.
  11. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    I think the OP is long gone.
  12. Erik Owens
    Erik Owens Member
    162
    60
    Fight, fight, fight,....I love tension in forums.
