How Do I Tell...
Discussion in 'Prius v Main Forum' started by Frank06, Aug 24, 2018.
  1. Frank06
    Frank06 Junior Member
    56
    Maine
    ..if it's a 2,3,4, or 5? 2012 with heated leather seats, nice car. But I can't find anything to differentiate which model level of trim it is. I apologize for the rookie question but appreciate any help.
    Frank
  2. ETC(SS)
    7,515
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,042
    6,920
    Texas Hill Country
    If it is a three your radio will have an XM label, there was no four, and if it has JBL on the radio it is a five. Otherwise a two. Both the three and five had navigation but the five had a higher end hard disk based nav option as well.
    This from a three, nav is accessed through the Apps button
    One of the Five radios with JBL
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Armed with the VIN, any Toyota dealer should be able to tell you.
  5. Offline
    Offline Active Member
    646
    240
    Lenexa, Kansas
    If you have the VIN, enter it on the following web page to find the information you are seeking and a lot more: Vehicle Specification | Toyota Owners
    If this Prius has real leather, then it is aftermarket leather which would not necessarily be a bad thing. Our Prius v Five came with seats covered with Toyota's "SofTex" vinyl which wears well but is not much like real leather.
  6. Air_Boss
    Air_Boss Senior Member
    4,248
    1,195
    New Yawk
    Surprisingly, the Toyota Owners' site does a poor job with 2012 v flavors. Our factory v Five shows as a Three.
  7. Offline
    646
    240
    Lenexa, Kansas
    And all this time you thought you had a Five! :rolleyes:
    Seriously, yours is the first report I've ever heard of the Toyota Owners site failing to provide correct information for a VIN. I've used the feature countless times myself and have helped many others on other Toyota oriented forums use it.
    It correctly shows our 2012 Prius v Five including information about its Advanced Technology Package and that its mudflaps and carpet mats were installed at the port instead of at the factory. It correctly lists all the information for the Camry we bought new in 1998 including its very unusual features for its day.
    Very odd.
  8. Frank06
    56
    Maine
    Thanks everyone!
  9. Air_Boss
    4,248
    1,195
    New Yawk
    Is it an early or late 2012? West Coast of East Coast POE? Ours is early, East.
  10. Frank06
    56
    Maine
    We have the XM radio but the VIN # says it's a Five. Actual wording is "Body Style: Five Model" and under "Grade" it says "NONE". What prompted my curiosity was I was starting to look at winter wheel/tire packages and tirerack lists a 16" package which didn't make sense to me.
  11. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Five had 17” wheels, but 16” will fit. Turning radius slightly wider with 5.
  12. Offline
    646
    240
    Lenexa, Kansas
    The "Five" also has XM radio but with a larger 7" screen. Our 2012 Prius v Five came with 17" wheels and tires but I downsized to 16" wheels and tires to get a wider selection and lower cost Winter tires. I bought a steel wheel Winter tire package from Tire Rack and wish I hadn't. They require poorly fitting lug nuts and wheel covers. The wheel covers I bought from Tire Rack are trash - still using all four but they're held together by strapping tape.
    I should have bought Winter tires from Costco where I usually buy tires. If I could have a do-over I would buy refurbished OEM Prius v 16" wheels from Wheels and Caps where I bought OEM wheels to use with Winter tires on our Sienna:
    aluminum-16x65-wheel-rim-69600
    Hubcaps are not needed with the 16" Prius v wheels - there are threads on this forum on where to buy Toyoto logo covers for their wheel hubs.
  13. mikefocke
    4,073
    1,858
    Sanford, NC
    With the 16" downsized summer wheels, what hub cover/cap did you get? Why won't that fit on your winter wheel set?
    I went the plastic hub center cover which looks OEM and the wheels under the original hubcaps were good looking I thought. Whoever buys my car will get a set of hubcaps with maybe 20 miles on them and a front drivers mat with maybe less because I went WeatherTech based on my experience with a prior car..
  14. Frank06
    56
    Maine
    I've bought several steel wheel/snow tire sets from tirerack and had good luck but I might buy alloy wheels this time. I agree the plastic covers are crap but I usually get 5-6 years out of them.
  15. Offline
    646
    240
    Lenexa, Kansas
    Sorry, I should have used the term "full wheel covers" which were what I bought in early 2013 from Tire Rack in a package that included four 16" steel wheels, TPMS sensors, and Bridgestone Blizzak WS70 Winter tires. IIRC, the plastic wheel covers were about $10 each - they are quite fragile, fit poorly and had to be modified to fit around the valve stems. I'm amazed that none of the wheel covers have been lost as they are very easy to pop off.
    When I bought this package from Tire Rack, OEM refurbished or replica Prius v wheels were not yet available at reasonable prices from resellers. The only reason I bought this package was to get the wheels. Normally I buy our tires and TPMS from Costco which I've found to usually be substantially less expensive than Tire Rack when all costs are considered ... plus there's a Costco less than one mile from our house. Costco includes lifetime tire rotation and balancing and usually no-cost or 1 cent installation.
  16. mikefocke
    4,073
    1,858
    Sanford, NC
    I go back to the MEMCO days before PriceClub and their ultimate merger with COSTCO. I still use my PriceCostco card dating to the early '90s.
    I have never seen a study on the effect of using the original hubcaps versus the hubcapless operation of the wheels.
