How do I test 12 volt auxillary battery?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jeffrimerman, Jul 11, 2018.
  1. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    I've research and see how the ones with nav can do it but is there a method for us non-nav peeps. I left a reading light on for a couple days so the car wouldn't start. I put a trickle charger 1.5a on it overnight and it seemed even worse the next day. Then I took my motorcycle battery out placed it in the trunk and using car jumper cables was able to start the car. I drove it around then was able to turn it off and successfully turn it on but that was just right after. I let it run some more and put back on the trickle charger. When I turned it off I used my voltage meter and it showed 12.7 volts at the terminals but I think it's supposed to be just above 13 volts. I've read to remove it and take it to pep boys for a load test. I've read to hit the lock button to turn off the car so it draws less power.
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    12.7 is good
  3. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Here's how to test the 12V AuxBattery from the driving seat, without any fancy tools/meters:
    DO-IT-YOURSELF TEST PROCEDURE (thanks to jdenenberg):
    - Without brake pedal, press the Power button once and release to enter ACC mode
    - Press and hold the MFD Info button, then turn the headlights on and off three times to enter Maintenance mode; release Info button
    - Press “Menu” (on screen)
    - Press “Display Check”
    - Press “Vehicle Signal Check” - the battery voltage is shown and should be about 12.4 to 12.8 Volts (normal for an unloaded battery)
    - Again without brake pedal, press Power button and release to put a current load on the battery - the voltage should stay above 12.0V (if less than 12.0V the battery is not well, or there is a fault or unusual load somewhere)
    - Press brake pedal and press Power button once to enter "Ready" mode - the battery is now charging at about 14V (if less than 13.6V or more than 14.4 there may be a problem with the charging circuit)
    - Turn car OFF to leave Maintenance mode
    -hope this helps - Wil
    Bay Stater likes this.
  4. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    I'll check it later tonight and see. On a side note I have no idea if it's the original 2010 battery. Maybe if I take it out I can see a date on it somewhere. If it's original maybe it's a good excuse to get a new one since they probably don't last past 8 years so much.
  5. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    Thanks Wil, but I think this method is for the ones with Nav right? I don't have nav =(.
  6. WilDavis
    2,493
    2,155
    49
    My 2009 Gen II doesn't have Nav, and this method works just fine!
    PS: 12V AuxBatteries only last 4 to 5 years, anything longer and you're chancing it! Good luck! :rolleyes:
  7. bisco
    52,697
    get a digital volt meter.
    pop the hood when you finish driving for the day.
    in the morning, open the hood and measure the voltage at the jump point in the fuse box.
    do not bring the fob with you.
    if it is below 12.5 volts, replace the battery.
  8. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    Oh ok yeah I had a gen 2 before and they had a nice color display. The gen 3 doesn't =(. I probably need to change it anyways since it's probably old and I'm playing with fire(but really electricity =P)
  9. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    Update,
    So far so good. I check the battery and it was 12.7 volts when car off and has been starting for a few days. The only thing I noticed is when I push the start button it seemed to activate the car, all the dash lights light up but the engine didn't do anything, then I hit the start button again and it started. It seemed like it went into the mode when you press start twice without having your foot on the brake. It did that 2 times so far. I'll google and see if that is in indication of the battery dying.
  10. bisco
    52,697
    your brake light switch might need adjustment, or push a little harder on the pedal.
    Jeffrimerman likes this.
  11. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    I noticed it did it repeatedly now. I've had to hit the start button twice while holding on the brake numerous times now while pushing hard. That sounds like it could be the culprit. I'll check to see if the brake light comes on with light pressure but if it does then that would eliminate the break light switch right? It has only ever done it now that I killed and recharged my 12v battery.
  12. bisco
    52,697
    yes, if the lights come on with average pressure on the pedal, the switch is properly adjusted.
    if the switch is good and it started happening after the 12v died, probably have to replace the 12v.
    are all the connections clean and tight?
  13. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    Looks like at least one other person had the exact same issue. I did check the brake pedal switch and it's fine from looking at the brake light come on. I check the voltage of the 12v battery and it's 11.8v so I bet it drops even lower the longer it sits. Ironically it started just fine when I went to check by pressing the start button. Sounds like it's just the battery.
    New Prius peculiar start-up problem | PriusChat
  14. bisco
    52,697
    yep. the computers can be finicky when it gets low.
  15. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    This sounds like somewhat of a misunderstanding to me.
    The gas engine is not necessarily SUPPOSED to do anything when the system is first started.
    Exactly when it actually runs is dependent on lots of factors, including which model it is.
    If you don't put the car into gear, it is possible that it might sit there for several minutes before the engine starts......especially if the A/C and other accessories are off.
  16. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    Sorry I should clarify. 100% of the time when I hit the star button the engine will come on within seconds and never has it not come on so not sure if that's another issue. Pretty sure it's normal for it to at least warm up a sitting engine. Also when you depress the pedal the engine should come on. The shift knob should allow the D or R to engage which it didn't also. I supposed if you just parked a warm engine then restart it then it won't necessarily come on but from a parked situation I've always had it come on. Bisco was right and I'm sure it's the 12v battery especially now that I see it's below 12v =(. Time for a new battery
  17. sam spade 2
    7,035
    2,804
    2017 Prius c
    Yes but my C will sit there sometimes for 30 seconds to a minute before it "decides" to warm up the engine......if you don't DO anything.
    AND.....if you are in P or N and the engine doesn't NEED to run for some other reason, pushing the gas pedal will do exactly nothing.
  18. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    Yes your'e right. I was just thinking we all have prius(es) so figured we all know pressing start isn't an immediate start if at all till we start to drive away sometimes. I'm sure some peeps still don't realize that but hopefully everyone here does.
  19. jaspernuts
    jaspernuts Junior Member
    25
    32
    Madison Lake, MN
    Is there a date stamped on the factory batteries? I would like to know how old mine is.
  20. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    I didn't see one but I didn't remove the battery to get a better look at the other side or the top.
    Edit: I googled and found this thread
    12V battery date code | PriusChat
