How do I USE connnect the auxiliary input in console? Blutooth?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Mar 19, 2019.
  1. ski.dive
    ski.dive Active Member
    864
    223
    Hutchinson Island,FL. Mt. Snow,VT
    How do I USE the auxiliary input in console? BLUTOOTH?
  2. MickyMatter
    MickyMatter Active Member
    260
    166
    Germany
    How do you want to connect bluetooth to a jack?!
    You'll have to connect a device with a cable with a 3.5 mm phone jack plug (male)(which fits into the car) to whatever your device needs (maybe a smartphone with a 3.5 mm too). You can use every device with a headphone or line-out connector. Maybe you'll have to use an adapter.
    When connected you can switch the audio to CD and instead CD the AUX will be recognized.
    SM-G950F ?
    Skibob and egg_salad like this.
  3. Skibob
    Skibob Senior Member
    2,912
    1,495
    Northern California
    If the CD is playing you have to push the button again to switch to AUX.
    MickyMatter likes this.
  4. Luc_S
    Luc_S Junior Member
    Poland
    There's a whole bunch of BT audio receivers you can connect to AUX. I'm using the cheapest one from China, unfortunately it's mono and the sound is contaminated with an unhearable while driving "digital hiss".
  5. oil_burner
    oil_burner Active Member
    249
    126
    I use a cheap bluetooth transmitter I got from amazon. It's made by taotronics. It was only $20 and I can charge my phone while playing music without having a loud hum from the charging interfering with sound quality, like when it was plugged in with the aux cable.
