How do we get Toyota to recall Gen 3 Priuses with head gaskets issues?
Discussion in 'Other Cars' started by Not124getul8r, Jan 30, 2016.
  1. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    How can you tell the difference between HG going or EGR clogged.
  2. ChapmanF
    18,156
    A leakdown test should confirm a head gasket failure if you have one. Finding traces of {oil, coolant, combustion products} in the wrong members of {oil, coolant, combustion products} is another common giveaway.
    Pulling up the EGR Flow Insufficiency test result in Techstream should give you an idea how clogged the EGR is or isn't.
    vvillovv and Mendel Leisk like this.
  3. Mendel Leisk
    41,417
    In the absence of techstream, the Exhaust Gas Recirculation pipe is relatively easy to remove, inspect and clean. If it’s got significant carbon build-up you can rest assured the Exhaust Gas Recirculation valve and cooler, and the small diameter Exhaust Gas Recirculation passages in intake manifold, will be similar or worse.
    it’s @NutzAboutBolts video #16 here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    vvillovv and orenji like this.
  4. orenji
    orenji Senior Member
    5,887
    3,488
    Just assume if you are near 100k miles, your EGR needs cleaning. If you wait on this, you may experience head gasket failure.
  5. Mendel Leisk
    41,417
    You can’t go far wrong if you follow the miles component of engine coolant change interval, for the full Exhaust Gas Recirculation cleaning: first time at 100K, subsequently every 50K. Even better: every 50K from the get go.
  6. Josette Julmiste Smith
    I bet the people that told you you were whining are eating their words. We need a class action lawsuit to get Toyota to recall these vehicles. This is ridiculous!
    #26 Josette Julmiste Smith, Nov 4, 2021
  7. bisco
    51,900
    all it takes is one fed up owner approaching a law firm. nah, not gonna happen, whining is more fun
