How do you clean the Mass Air Flow Sensor on the Gen 3
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by heyphillip, Apr 22, 2017.
  1. heyphillip
    heyphillip Member
    131
    47
    Maple Shade NJ
    2010 Prius 4
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    I bought the CRC MAF sensor cleaner that comes in a can at AutoZone or the like. With the velocity that comes out of the can, it does a good job of getting the sensor.
    With easy access to remove the MAF, this is a quick 10 minute job:).
    Hope that helps(y)
  3. bbui13
    bbui13 New Member
    San Jose, CA
    No it did not help... It would be better if you have picture showing where the MAF is
    ivfx likes this.
  4. Mendel Leisk
    42,343
  5. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    2 Phillips head screws and the wire harness connection and you have it removed and accessible ;).
    Thanks for digging in your library @Mendel Leisk (y).
  6. Mendel Leisk
    42,343
    Don't let anyone know, but I just googled "2010 Prius MAF image". :whistle:
    Raytheeagle likes this.
  7. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Your secrets safe with us;).
    Now if it was that easy for you to google it.......:sick:
  8. Currahee
    Currahee Member
    103
    34
    CT
    I've cleaned the Gen 2 throttle body and MAF sensor a couple times but on the 2010 they're always pristine. Gen 3 air filter does a much better job keeping out dirt.
