How do you get the fuse box cover off
Discussion in 'Gen 2 Prius Main Forum' started by Oxo, Jan 5, 2006.
  1. PatrickEE
    PatrickEE Junior Member
    Michigan
    Four Touring
    upload_2024-2-24_21-57-4.jpeg upload_2024-2-24_22-0-44.jpeg Press the front hook towards the rear of 2008 Prius and lift up the fuse cover. Hook is between 20mm and 33mm marks. Thanks KMO for the best advice! Brute force unhooking 2 hooks at rear is wrong, difficult, and won't release front hook.
  2. pasadena_commut
    pasadena_commut Senior Member
    3,070
    956
    Southern California
    Well it finally happened, the broken rear tab which had been dangling by a very thin bit of plastic finally let go completely and wandered off into the great unknown. Now with only the innermost of the two rear tabs still present, and the front latch engaged, the lid holds down, but not all that well. The part where the missing tab is can lifted up a few millimeters with no effort at all. It may let some dirt in.
    Repairing that missing tab looks like it won't be easy. Any idea how much clearance there is between the top of the fuse box and the bottom of the hood? If it's just an inch or two maybe a block of rubber glued to the lid will hold it down tight?
