How do you know how much electrical charge is left in the Prius Prime PHEV?
Discussion in 'Prime Main Forum (2017-2022)' started by charliebrownsprius, Oct 26, 2020.
  1. charliebrownsprius
    charliebrownsprius New Member
    17
    2020 Prius Prime
    On the left side of the dash, there is a fuel gauge. How do I get something similar on the dash to show how much charge is left in my battery? I know it has a 40km capacity but I'd like to know what is remaining.
    Thank you
    #1 charliebrownsprius, Oct 26, 2020
  2. Tideland Prius
    16,443
    Press the upload_2020-10-26_11-26-54.png button on the right side of the steering wheel to change the menus on the MID to the "Settings" upload_2020-10-26_11-27-59.png menu. Press "Enter" ( upload_2020-10-26_11-27-22.png )
    Press upload_2020-10-26_11-27-36.png to scroll through the Settings menu until you reach "Meter Customise" upload_2020-10-26_11-29-29.png . Press upload_2020-10-26_11-27-22.png . Scroll up/down upload_2020-10-26_11-27-36.png until you see "HV System Indicator". Press upload_2020-10-26_11-27-22.png then scroll to "EV Drive Monitor". Press upload_2020-10-26_11-27-22.png . Select EV Energy.
    Keep pressing "Back" upload_2020-10-26_11-31-23.png until you exit the Settings menu. You should see the EV Distance change to a % based SOC readout (see below) on the Hybrid System Indicator screen.
    #2 Tideland Prius, Oct 26, 2020
  3. schja01
    schja01 Senior Member
    1,820
    1,207
    Chicagoland
    2024 Prius
    Limited AWD-e
    Flip through the Trip Odometers. One displays estimated EV miles left.
    #3 schja01, Oct 26, 2020
    Tideland Prius likes this.
  4. charliebrownsprius
    17
    2020 Prius Prime
    This is fantastic, thank you for taking the time to post this, I will try it tonight
  5. Tideland Prius
    16,443
    Np. You can use @schja01 's method to have both the EV Distance Remaining and the SOC% displayed at the same time if you wish to build some sort of correlation. Not sure if it works. I have the Upgrade w/ Technology Package so I use the HUD to display the Distance Remaining. I find it fairly accurate after you've driven about 5-10km. It's not accurate at the start of the day because it's only based on the last drive so if it was warm the day before and it got cold today, your EV range will be wildly optimistic until it figures out you're using the heater and the battery is cold etc then it'll adjust. E.g. if it says 60km in the morning after a full charge, I'm usually getting 52-55km depending on traffic. It's least accurate during transition months like Spring and Autumn since changing or fluctuating temperatures can play havoc on range, especially a range this short).
    Your 40km range will change depending on your driving habits, outside temperature, tyre type (all-seasons, winter), climate control setting (temperature setting, heater use, cooling use), road surface (snow covered, standing water or bare dry roads) etc.
    I've ranged from 25km to 63km between the seasons. It's ok to use fuel in the winter since you'll probably not use any fuel in the summer (unless you have a long commute) and so it's good to "purge" the tank once a year imo. (And the owner's manual recommends adding at least 20 litres of fuel in total every 12 consecutive months).
    Or something that's easier to compare (using the Eco Diary page). In the summer, I'm at 9.1-10.5kW/h100km. In the winter with rain or snow, I'm closer to 15-18kWh/100km. Once it rains, your consumption goes up due to water on the road (Extra drag) and then factor in the colder temperatures and usage goes up.
  6. charliebrownsprius
    17
    2020 Prius Prime
    I was kind of surprised you are getting "25km to 63km". I assumed we wouldn't get more than 40km as that is what the battery is rated for.
    BTW, thank you again for the instructions on the display, I just tried them and they worked
    #6 charliebrownsprius, Oct 26, 2020
  7. Tideland Prius
    16,443
    Well the number given is meant to average over the entire year which if you think about it, is pretty close given my usage case (unless you live in the Prairies with extreme cold or in Atlantic Canada with heavy dumps of wet snow, both will significantly reduce range and in the case of the Prairies, you'd be running the engine for heat below -10°C).
    63km was my record. I typically get 50-55km in the summer. Also, 25km was my worst ever.
    2020 Prius Prime and Extreme Cold... | PriusChat
    (I had 5km range left so I estimated 25km). AM temp was -7°C and PM temp was -3°C.
    The 40km is based on 15.8kWh/100km energy consumption so if you're beating that, you'll get more than 40km.
    Note that as winter approaches, pre-heating the cabin becomes important - it allows you to pre-heat the cabin using wall power (mostly... minor details if you want me to explain) so when you drive off, your climate control only needs to maintain the cabin rather than heat it from a cold start (which draws a lot of power). In addition, it helps keep the battery warm (again for more range). At 5-10°C, you'll probably see a 2-3% SOC hit starting with a cold cabin and battery. I assume more if it's at or below 0°C.
    Here's a link to estimated electrical consumption of various electrical items on the Prius
    Estimated EV penalties for various heating cooling and lights | PriusChat
    (mid beams... he means parking lights. and normal being low beams)
  8. AldoON
    AldoON Member
    108
    79
    Milton, ON
    2018 Prius Prime
    Upgrade
    Does anyone know of a way to display the battery percentage on any screen other than the eco display?
    Perhaps somewhere in the touch screen?
  9. Salamander_King
    Salamander_King Senior Member
    11,005
    8,929
    New England
    I don't think so. The numerical EV energy % can be displayed only in the HSI. However, the graphical battery charge level, Hybrid battery (traction battery) status, can be displayed on the split sub-screen.
  10. charliebrownsprius
    17
    2020 Prius Prime
    Sorry for the newbie question, but how do I measure my kWh/km energy consumption?
  11. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    The battery holds a certain amount of electrical energy. It isn't rated for a distance. The EPA tests show it will propel the car an average of 25 miles on a full charge. They estimate that a full tank of gas will propel the car an average of 615 miles. (That's subtracting 25 from Toyota's advertised combined range of 640 miles.) None of those are ratings; they are averages derived from very specific conditions and driving styles. It would actually be rare that one would happen to match those conditions and styles. Most Prius drivers do much better, in fact. The EPA says my car gets 53 mpg city. Actually, I get more like 65-70 mpg in town in hybrid mode.
    #11 jerrymildred, Oct 27, 2020
  12. Salamander_King
    11,005
    8,929
    New England
    Should be 615 miles and 640 miles.;)
    #12 Salamander_King, Oct 27, 2020
    jerrymildred likes this.
  13. jerrymildred
    11,517
    14,137
    Tampa, FL
    Thanks. I'm recovering from some kind of flu and the gray cells aren't working like they should. Error caught and fixed before the editing period expired. :notworthy:
    Salamander_King likes this.
  14. Salamander_King
    11,005
    8,929
    New England
    It is on your Drive Monitor 2 for life time (provided you have not reset the EV efficiency data). It is also shown in the Eco Diary for a day or a month average.
    #14 Salamander_King, Oct 27, 2020
  15. Tideland Prius
    16,443
    Page 223/224 of the owner's manual. The Eco Diary is the easiest to find the kWh/100km readout. Unfortunately, there's no "trip" readout like there is for L/100km. You only get instant (which is useless since the scale tops out at 10kWh/100km and you're usually above it) and the Eco Diary which is a daily and monthly average. I use the daily one since that's the closest I can find for short term readouts.
    Drive Monitor 2 that @Salamander_King suggests is for long term (as long as you did not reset the "odometer" fuel consumption average via the TRIP button or accidentally press "Update" on the 7" MFD on the Consumption Screen page.)
