How do you reset ABS light & yellow ((!)) with Mini VCI and techstream
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by chavezone, Jun 12, 2014.
  1. pkwhisker
    pkwhisker Member
    146
    23
    Hurst, TX
    I have brakes even though the break lighrs on I think I lose breaks when the buzzer sounds
  2. JC91006
    16,939
    8,647
    If this buzzer goes for no more than 10 seconds, during startup and shut down, that would be the coolant pump to the thermos
  3. pkwhisker
    pkwhisker Member
    146
    23
    Hurst, TX
    Buzzer ONLY goes off after I have been driving.. Never at startup
  4. pkwhisker
    pkwhisker Member
    146
    23
    Hurst, TX
    So far driving brake light ABS/VCS ON Weird codes didn't get them cleared on VCI
  5. pkwhisker
    pkwhisker Member
    146
    23
    Hurst, TX
    Okay buzzer came back on and it disengage my brights with that red triangle ... Heading back home so I can read the codes
  6. JC91006
    16,939
    8,647
    can the buzzer be from overheating? like when a computer overheats, it'll buzz you
  7. pkwhisker
    pkwhisker Member
    146
    23
    Hurst, TX
    Good point!!!!
  8. pkwhisker
    pkwhisker Member
    146
    23
    Hurst, TX
    Got fresh codes
    u0129- medication with brake system
    c1345
    u0121 again
    b1421 again
    I went into the AC module and it had this under the big list of all the parameters I found it strange that this had a zero as a value :solar sensor (d side). =0
    I don't know that last one might not mean anything I could've been I picked it out of a huge list because it's only thing that I saw 0 on
  9. pkwhisker
    pkwhisker Member
    146
    23
    Hurst, TX
    The only odd thing is that the buzzer came on because it was overheating what that disengage the power brake system ?
    #49 pkwhisker, Jun 23, 2015
  10. pkwhisker
    pkwhisker Member
    146
    23
    Hurst, TX
    Another thing that is strange that I noticed and somebody that was riding with me the other day said it seems when the brakes are disengage the only manual one that I have is the back right rear one
    So it seems I really have to pump it slowly and it only seems to be coming from that back rear brake I find that very strange Toyota would do that that's dangerous
  11. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    Did you do the zero point calibration?
  12. pkwhisker
    pkwhisker Member
    146
    23
    Hurst, TX
    I tried to do it I know I went in there and did some calibrations that's where the lights blink and all that kind of thing and then it counts down for like 75 seconds ? Could you tell me the menu path again and just make sure that I did that correctly ?
  13. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    PK,
    I am interested in your thread but I cannot understand 2/3rds of what your write. Please, please, use punctuation and take a moment to fix typos and write coherent sentences.
    Thanks.
  14. pkwhisker
    pkwhisker Member
    146
    23
    Hurst, TX
    I'm sorry I'm in the garage and trying to type with one hand so I'm trying to get all this information at once I will do better
  15. pkwhisker
    pkwhisker Member
    146
    23
    Hurst, TX
    Thank you everyone for your help .. I read above and now I realize my phone was auto completing words (wrong ones) so no wonder some of this didn't make any sense I apologize for that
    I'll just take it into the stealership and let them have a go out at and I'm sure they're going to push a ECU module on me but I'm going to hold out in hopes they will find the root cause
  16. Avi's Advanced Automotive
    776
    363
    Wait, do the calibrations first. First: Techstream > ABS/VSC/TRAC > Utility > Reset memory > follow directions. Second: Techstream > ABS/VSC/TRAC > Utility > ECB utility > Linear valve offset > follow directions. Car must be on level ground and I recommend doing it with a battery charger attached.
    JasWalker likes this.
  17. pkwhisker
    pkwhisker Member
    146
    23
    Hurst, TX
    I could run out and do it now but I'm concerned what yoy said about needing a battery charger ?
  18. Avi's Advanced Automotive
    776
    363
    If you don't have one, you can still try and see what happens. If your battery gets low, it will not complete the calibration.
  19. JC91006
    16,939
    8,647
    I thought her battery was at 12.9 volts a few threads/posts ago
    pkwhisker likes this.
  20. pkwhisker
    pkwhisker Member
    146
    23
    Hurst, TX
    Doing it now
