How do you reset ABS light & yellow ((!)) with Mini VCI and techstream
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by chavezone, Jun 12, 2014.
  1. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    That's part of why I said it should be fine without it.
  2. pkwhisker
    pkwhisker Member
    146
    23
    Hurst, TX
    Ok. I just completed both those calibrations and they are the same ones I did last night because I remember the procedures now going through it again .
    Ran a health check and this time the only code that shows up is B1421
    Just read 1421 Code is Bogus as its in the shade. Thanks again for all your help I'll just give an update tomorrow if it all comes back on like I expect ...I will have to take a visit to the stealer ship and see if they can help me in anyway I give up
    #62 pkwhisker, Jun 24, 2015
  3. Patrick Wong
    18,214
    6,531
    You already have determined that B1421 is not a problem.
    U0129 is logged by the hybrid vehicle ECU and U0121 is logged by the power steering ECU. Both of those ECUs are reporting there is no communications with the skid control ECU via the vehicle controller area network (CAN). This is like a computer local area network.
    It is probably time for you to seek professional assistance if the codes return, unless you are up for trying to figure out the communications problems by following the troubleshooting process as described in the repair manual. You need a multimeter so that you can measure resistance, and you need access to the skid control ECU which implies dashboard disassembly. You would use the multimeter to determine resistance across the CAN bus line as viewed from the skid control ECU. You would also verify the presence of ground and 12VDC at various wiring harness connector pins that connect to the skid control ECU. If the comm measurement is good and the voltage measurement is good, then the skid control ECU would be deemed faulty per the troubleshooting tree.
    This task is more than a casual project.
  4. pkwhisker
    pkwhisker Member
    146
    23
    Hurst, TX
    Thank you Patrick .. Excellent diagnostic information as usual from you . Yes I decided last night it was going into the shop .. It does make sense what you explained ... The only thing I find so perplexing is for almost a solid week it kept throwing a code for the left front wheel sensor ... Kept throwing that code 2 days even after I replace that sensor .. What I find so perplexing is why is it now throwing a different set of codes like these it seems to me the codes are changing all the time but it does make sense there is some kind of communication blockage going on to the ECU . I don't really think the stealerShip goes into this kind of troubleshooting I think They see a code after running their software diagnostics then just want to replace a part... but I'll ask them in fact I think I will take it to another one in the area I don't really trust the first one .. Thank you again for your excellent feedback !
  5. Patrick Wong
    18,214
    6,531
    Yes, that is very troubling. If this were my car I would access the skid control ECU, remove the wiring harness connectors, spray electrical contact cleaner into the connectors and the ECU connector sockets, then reassemble and see if that helps. Possibly intermittent connections might be inducing these fault codes, especially if the car has been in an area of high humidity.
    Good luck with your search for an honest and technically competent repair effort.
  6. pkwhisker
    pkwhisker Member
    146
    23
    Hurst, TX
    That's good advice Patrick I'll see if I can talk to them and try to give them a little bit of history and see if they'll work with me on doing this ... Actually Texas has had historical rainfall in the last three weeks and we have had a lot of humidity now as a result.
    Thank you again and I will keep you posted to the out come
    One last question. Should I let the dealers know what the codes and possible troubleshooting that will need to be done when I call them, or should I let them do their own troubleshooting? I can say a friend has a small shop and tried to help me and I have the history on the codes and the issues over the last week, and what troubleshooting would need to be done, but not sure how much I should tell them. If it were me, I would want as much history and information as possible, but then again I'm not a Prius Technician or a Service Manager at a Stealership.
    #66 pkwhisker, Jun 24, 2015
  7. Patrick Wong
    18,214
    6,531
    Well, I don't think it hurts for you to say what codes you retrieved and what action you took. That shows that you are more informed than 95% of auto owners, and may help as you discuss what needs to be done now.
  8. pkwhisker
    pkwhisker Member
    146
    23
    Hurst, TX
    Ok Patrick I agree that makes sense .. okay I shall do this!
  9. chavezone
    chavezone Junior Member
    71
    16
    Las Vegas, Nevada
    Hello guys, looks like my thread was hijacked in my absence so please forgive me if I have renewed an old thread but this issue still exists and I am now in th3 position to afford parts and have the car in my possession.
    My daughter had it up in college so I had no access to the car, she is back home now and i parked it for about 6 months now.
    Patrick I found a used skid control ecu from a hybrid repair shop in town and replaced it and also replaced a bad cell in the hybrid battery, I just installed the hybrid battery yesterday and tried firing it up, all lights are still lit up and the engine will not fire up, it won't go into drive or reverse, i checked the 12 volt battery and it was a bit low 11.2 volts from sitting so long, I am charging it overnight and hoping it being unplugged will clear the lights is also unplugged, we'll see
    #69 chavezone, Mar 14, 2016
  10. chavezone
    71
    16
    Las Vegas, Nevada
    Hello Avi sorry for not responding sooner but as you can see from my above post I have some difficulties getting the car in my possession, I also was told by dealer that the ecu was faulty because they couldn't get it to communicate
  11. chavezone
    71
    16
    Las Vegas, Nevada
    Patrick, I just wanted to follow up on my ongoing problem, the car sat for quite a while and I finally broke down and took it to a local honest Hybrid repair shop, a place here in Vegas called Hybrid Auto Center knew exactly how to fix my problem just by reading the codes as well as listening to the engine run.
    It turns out the Brake Pump was bad and was the reason the Zero Point Calibration could not be reset, he pointed out to me the high pitch sound the pump makes, he said that sound is normal from the pump but should only make it every 30 seconds or so, my car was doing it ever 3 seconds, he knew that was the issue because he has had several other Prius's brought in with similar issues.
    He replaced the pump and 1 bad hybrid cell and the car is back in business, I did have another issue pop up now, the CEL has turned on throwing P0420 code which is a totally separate issue, hoping I could clear it with some maintenance so I can get rid of this car.
    Just wanted to be sure and share my experience so if someone else is having the same issues to check the pump and not replace the compter like I did.
    Hope that helps.
    amos and fotomoto like this.
  12. amos
    amos Active Member
    376
    285
    los angeles
    @Avi's Advanced Automotive i am here in lo angeles too ( olympic la cienega). i have codes c1345 c1451. went to dealer with other issue completely now they say i need to change that ecu for over $4000. i think they made a short circuit when they tried to connect their scanning tool, i have christmas and hannuka lights at the same time. abs, traction control, ((!)) , emergency brake. i have no regenerative and battery charge is very slow.
    car is there at dtwn toyota dealership for 3 days now. i was not charged for anything yet, i am convinced they were the ones to blame.
    #72 amos, Dec 12, 2017
    Raytheeagle likes this.
  13. ChapmanF
    19,060
    They must have a boat payment coming due.
    Neither of those codes mean anything like the ECU needing to be replaced. The C1345 means that the ECU got reset at some point and lost the values it learned for the linear solenoid valve offsets. All you do is tell it "hey, go learn the linear solenoid offsets again", and it does, and the code goes away. You can do that like this. It can be done with Techstream, or just with a short piece of wire with skinny ends. It's a completely routine thing to do.
    The C1451 is a protect-you-from-yourself code that disables the electronic braking if a certain maintenance mode has been used where it's possible you might have done work that let air in. The code goes away after following the Techstream brake bleed procedure. I know of no other way to make that code go away; disconnecting power doesn't clear it. The regular brake code clear doesn't clear it. It is there to force you through the bleed procedure, even if you know full well you did nothing to let air in and it isn't really needed. You just say "sure, ok", start the procedure, follow the steps, and the code goes away. That's it.
    Now, if they're absolutely sure they've been through exactly those steps, and they're sure they did them correctly, and the codes really haven't gone away, that could possibly indicate a bad ECU. I would much sooner bet, though, that they have just been fussing around with all the other reset and clear tricks they've ever heard of, and wondering why they haven't worked, instead of just doing the two simple things the manual tells you to do when you have those two codes.
    -Chap
  14. JC91006
    16,939
    8,647
    If you want to find Avi's shop, he's around USC. Hybridfix.com
    amos and Raytheeagle like this.
  15. amos
    amos Active Member
    376
    285
    los angeles
    @ChapmanF . Thanks for that post i needed that one..it makes me strong. Knowledge is power and i will soon use it to show dealer im not a p*****y.
    Dealer did nothing but resetting system with that 12v battery. They dont want to spend anytime on it .i opened a case with toyota hq today. You know dealers much rather go on collectiong $150 for oil change untill i will show them im standing against them.
    I still know and remember something very simple. When i went in there. The guy who wrote the ticket was with me in the car .nothing displayed on my dash.
  16. amos
    amos Active Member
    376
    285
    los angeles
    Oh nice. Dealership is right there by fig and adams. Thanks @JC91006
  17. ChapmanF
    19,060
    You're welcome.
    It occurs to me that it might be necessary to deal with the C1451 first (as it disables electronic braking control, so it might not be possible to touch off the linear solenoid learning until after that's resolved). Trying in the wrong order might also make them think "dang, must be something wrong with this ECU!"
    -Chap
    amos likes this.
  18. amos
    amos Active Member
    376
    285
    los angeles
    @ChapmanF my car is back to normal all o.k dealer didnt get any money from me. I had to take my car out of there. They couldnt care bout what they did and nothing helped. So i took the car to @Avi's Advanced Automotive and we followed that bleeding process. We didnt even bleed it just followed the process step by step. 10 minutes after that all was ok. Back to normal. Avi is a great guy. .i mean it. He helped me for free. And something dealer wanted 4,0000 to fix turned to be exactly as you said. I thank you a lot for that knowledge you provided. Gave me lots of confidence. @JC91006 thank you too for helping me to find avi.
    Downtown l.a toyota dealer behaved like a monster.nothing helped they pushed all on me and said bad computer was there long before. Just predetors with no shame. Even toyota hq didnt help . @Raytheeagle
    @Mendel Leisk thanks
    #78 amos, Dec 16, 2017
    Prodigyplace and Raytheeagle like this.
  19. JC91006
    16,939
    8,647
    Maybe the dealer just wanted to sell you a new car. Take your broken car in for $500
    A little conflict of interest with sales and repair together
    amos likes this.
  20. amos
    amos Active Member
    376
    285
    los angeles
    U so right. This whole structure over there is brand new like two weeks old. I guess they are going crazy to find someone to pay for all those bills piled up there.
