How do you reset ABS light & yellow ((!)) ?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Michael Carleone, Mar 20, 2015.
  1. ChapmanF
    18,961
    I haven't felt like trying it again, so I haven't experimented with many variations. As it happens, there are also two ways to select Invalid Mode, a Techstream way and a non-Techstream way. I was using Techstream at the time, so I used the Techstream utility to go into Invalid Mode. And I got the C1451.
    I do believe I've read posts here by others who said they worked on their brakes without Techstream, and used Invalid Mode, so I assume they used the non-Techstream way of invoking it, and those threads do not all end with "... and now what do I do about this C1451?" ... so maybe it matters which way you get there.
    I'll let somebody else do the experiment. :)
    -Chap
  2. abdelellah
    abdelellah Junior Member
    25
    37
    Amman, jordan
    thanks man for the detailed info.
    I got all the trouble that you already mentioned, but though, now my dash Christmas tree warning lights off
  3. song_cr
    song_cr New Member
    Australia
    i-Tech
    Dude u saved my nice person! My car is 2014 Camry Hybrid. I was playing around with Techstream and found there was an ECB invalid option.
    I did that and when I start my car, those warning lights totally freaked me out and same as yours, I lost ECB.
    That hydraulic braking doesn’t feel safe to stop the car...
    I tried air bleeding (it kept losing communication for five times), but the ECB still didn’t work until I did the “memory reset”, “zero down” and “linear solenoid valve offset learning”.
    Now I even feel the brake is more sensitive and accurate.
  4. song_cr
    song_cr New Member
    Australia
    i-Tech
    Oh it replaces “a s s” with “nice person” lol
  5. Cooidude0
    Cooidude0 New Member
    Pennsburg
    Thanks for posting this, I used TechStream to put my car in Invalid Mode, ran a bunch of tests and then the air bleeding, but could not get it back to normal mode. I did the 3 things mentioned including Linear Solenoid Vale Offset, after that it went back to normal mode.
  6. Tashfeen
    Tashfeen New Member
    Malaysia
    @ChapmanF
    Not sure if you are still active here , if you are, much appreciate your advise.
    It seems you used techstream with OBD Dongle (ELM327), I did not know techstreat (from laptop) could be used with a dongle.
    Please do advise how this may be done.
    thank you, much appreciate.
  7. ChapmanF
    18,961
    Any dongle that conforms to the SAE J2534 standard will (theoretically) work.
    J2534 conformance really comes down to a suitable software driver (Windows DLL file) being supplied for the dongle you are using. Yes, it has to be a Windows DLL file, as J2534 is a Windows-specific standard (I imagine many corks got popped in Redmond when SAE was hoodwinkedtalked into approving that).
    You can find threads about various J2534-supporting dongles around here if you search.
    Brian1954 likes this.
