How do you reset ABS light & yellow ((!)) ?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hoogax, Dec 7, 2009.
  1. harryarcos
    harryarcos Junior Member
    81
    24
    London
    As it was a while ago, I thought it might be useful to start with a quote of Paul's advice on resetting the ABS light etc., with a jumper on the OBD2 port. Like many others, I thought replacing the front pads on a late 2004 Prius would be easy. Done it many times on Saabs, but still looked at 'Haynes' to make sure there was nothing out of the ordinary. Wrong! Should have looked here first. - Haynes needs an update. I did not disconnect the battery or remove any relays etc.
    I now have a car with locked front brake pads and displaying 3 yellow lights - VSC - ABS and Brake system warning light (along with the red one). Unfortunately, the jumper trick does not seem to work on the earlier model, but rather than risk a paper clip, I cut the plug off an old OBD2 and soldered a wire between the CG and TC pins to make a safe bridge - if anyone wants to do this, be warned that the pins are numbered differently on the inside of the plug, so DO NOT just solder 4 and 13 but make sure that when plugged in, the socket pins 4 and 13 are the ones that are connected.
    If anyone has any advice on how to sort out my problem Prius, I would be most grateful for any reply. Failing that, it looks like I might need to read up on 'Tech Stream'. Hope this post helps someone else.
  2. JJB1020
    JJB1020 New Member
    Normal, IL
  3. JJB1020
    JJB1020 New Member
    Normal, IL
    Thanks for the info Paul, saved my frustration after doing a fluid change today...
    JB
  4. Snookay
    Snookay Junior Member
    I put my 2006/7 on a uhaul tow dolly. After a 15 mile trip these 4 lights were on my dashboard. I tested my ABS and sure enough it was not enabled. I just did the paper clip trick and the lights turned off. I have no yet tested the care to see if my ABS is working again but I will later during the drive home. Thank you, thank you, thank you! A dealership wanted to charge me slightly under $100 to attach there code reader and reset it for me.
  5. bisco
    52,849
    congrats, all the best!(y)
  6. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    The HV battery is a high voltage battery that could kill you straightway.
    The battery in your explorer, is a 12volts battery, so won't work.
    Maybe I didn't get you well though.
    Are you saying you want to use your explorers 12vokt battery to JumpStart the Prius aux battery in your car, or what?
    If that's what you mean, definitely it can be used.
    Have dried that before, using JumpStart cables
  7. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Bisco! You seemed to be on brake all this while?
    Just seeing your comments today for the first time.
    Hope you're good?
  8. bisco
    52,849
    doing well, thank you! i'm always on break.:p
    Raytheeagle likes this.
  9. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    You're a funny men. Got you now. Not on "brake", but break. :D
    Raytheeagle and bisco like this.
  10. Joshua Han
    Joshua Han New Member
    Valencia
    what windows do you power down half way and for how long do you have it halfway open for. I saw this somewhere else online a while back but couldn't find it.
  11. Mendel Leisk
    42,343
    You do this with any window that's not doing auto-up correctly, ie: a single up touch and it doesn't continue on it's own.
    Hold down switch till halfway down, then hold up switch till it's all the way up, and continue to hold up switch for at least 2 more seconds. That should fix it.
  12. Joshua Han
    Valencia
    I was aking to reset the abs light deal not the power windows
  13. Patrick Wong
    18,210
    6,517
    See post #7.
  14. Eddie Mudiwakure
    Eddie Mudiwakure New Member
    Manchester
    ----UK----
    Thanks Paul the paper clip advice worked well. Great stuff
  15. Illtoys
    Illtoys Junior Member
    Thank you Paul Haller! Worked on my 2004 Prius. Any Idea if it works on a 2001 Highlander?
  16. DrewG13
    DrewG13 Junior Member
    45
    New Jersey
    Would this work on a 2013 Prius?
  17. chelvis
    chelvis Member
    85
    50
    Long Valley, NJ
    I don't know if it will work with a 2013, it worked on my 2005 last week. The rear drums were replaced and the ABS idiot light came on. Jumper worked like a champ.
    DrewG13 likes this.
  18. DrewG13
    45
    New Jersey
    I didn't pump the brakes before I removed it. I saw a video which just showed turning the key on, letting the lights flash for 40 seconds, turning the car off and removing the jumper.
  19. chelvis
    chelvis Member
    85
    50
    Long Valley, NJ
    No, you have to pump brakes just like Paul's method states.
  20. DrewG13
    45
    New Jersey
    Going to try it now.
