How do you use your headlights?
Discussion in 'Gen 4 Prius Main Forum' started by gvp1995, Aug 23, 2016.
  1. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    I can't believe how many vehicles I see, driving around in the dark, with no headlights on. They must be thugs trying to be anonymous, or they are some very absent minded people.
    When I do use the "Auto/DRL" setting, which is always, sometimes it will beat me to turning on the headlights at dusk because I changed the setting to "most sensitive." (It's in the big Darth Vader screen, under vehicle settings/lights.)
    RCO likes this.
  2. Kenny94945
    Kenny94945 Active Member
    863
    439
    Sausalito
    2016 Prius v wagon
    For the most part, I leave on auto and forget it.
    I also have the headlight off delay at 30 seconds...the lowest setting.
    If bulb life is a concern...turning off the delay could be advisable.
    If parked/ idling turning off manually could also be advisable.
    Else I force the H/Ls on smartly...rain, grey weather, when I wish to be seen such as in crowded traffic or fast moving traffic and other scenarios as need be.
    Again, auto function works for me.
    I can see your concern as you have experienced too much in repair costs for your H/Ls.
    Good luck.
  3. Tideland Prius
    16,668
    The latter. Those people upgrading from a car built in the 80s, 90s and early 2000s that are not luxury vehicles, are not used to cars with electronic instrument clusters or LED backlit instrument clusters. Both types have their dials illuminated at all times so at night, the combination of the illuminated speedo plus DRLs fool people into thinking they have their lights on.
    You would think the extra bright cluster would give them a clue.
    RCO likes this.
  4. Coast Cruiser
    2,267
    2,571
    "You would think the extra bright cluster would give them a clue."
    ...Or the lack of headlights on the street!! :ROFLMAO:
  5. Tideland Prius
    16,668
    It depends!! The Corolla and new Prius in Canada use the low beam headlights (only slightly reduced intensity) as DRLs so it really does look like they're headlights are on.
  6. roadwarrior28
    roadwarrior28 Member
    68
    69
    Portland, OR
    Three Touring
    Does anyone know the warranty/replacement information in the event of failure. LEDs are obviously very efficient, but what happens if the led dies? Is there a way of replacing it without replacing the whole projector unit/assembly?
    I keep my lights on AUTO and set the threshold for the lightest setting (Carista not needed :p) and I find it works very well. I only wish you could change the DRL to the Fogs or something else, and also have the rear taillights come on as DRL (Scandinavian DRL lighting, common on European cars)
    A question for the Europeans in this thread..Does your Prius come with an Auto-leveling system? NA models do not and I was under the impression that it was law to have auto leveling with HID or LED...
    RCO likes this.
  7. raspy
    raspy Senior Member
    438
    699
    London, UK
    Yes. From my manual,
    "Automatic headlight leveling system
    The level of the headlights is automatically adjusted according to the number of passengers and the loading condition of the vehicle to ensure that the headlights do not interfere with other road users."
  8. roadwarrior28
    68
    69
    Portland, OR
    Three Touring
    Thanks for the clarification. I do wish we got an auto leveling system here in the states as the lamps are very bright...
  9. booke02
    booke02 Active Member
    391
    415
    Israel
    Do you have manual button for adjusting the level?
  10. roadwarrior28
    68
    69
    Portland, OR
    Three Touring
    Not in the cabin. There is of course a screw on the headlight housing, but that involves going under the hood to adjust the lights, impractical for quick load adjustments. I would be curious to see if there was a way to retrofit OEM leveling motors into it to at least have a manual option if it is indeed available in other markets.
  11. booke02
    391
    415
    Israel
    That sounds crazy. I can't believe that Toyota don't address the issue in some manner - either with auto-leveling or an easily-accessible manual option!
    RCO likes this.
  12. Tideland Prius
    16,668
    It's not explicitly mentioned for Gen 4. For Gen 3, it's mentioned even in the brochure that there is auto-levelling.
    That said, yeah we cannot assume that the Gen 4 has auto-levelling.
  13. Kremtok
    Kremtok Smug Alert!
    100
    74
    Homer, Alaska
    I keep mine on at all times, on the 2016 as well as the old 2008 before I sold it. HIDs went bad after a couple of years in the 2008 but the replacements were covered under warranty both times. Hopefully they'll last longer in the 2016.
    Coast Cruiser likes this.
  14. fuzzy1
    10,687
    In the U.S., an easily available manual option would be crazy. It would be ignored or abused more often than it would be used correctly.
    RCO and krmcg like this.
  15. gvp1995
    gvp1995 Active Member
    199
    141
    Three Touring
    I now have the answer how I should use the lights. I found the "Daylight" feature in the Settings. So when you check that box + you put your switch in Auto, the lights are always on during the day. It does not show on the dashboard however, but they are ON.. When I drive into a dark parking lot than the light sign is ON and everything inside is illuminated. And of course the car turns the light OFF after some halve a minute. So Auto + Daylight ON is the best combination for me. In my view it is better than turning it ON and OFF manually every time (although it was something I was doing on my Gen 2). And it is better than having it always ON. There is actually another thread on this forum discussing this.
    RCO and Tideland Prius like this.
  16. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    In UK we call that feature "dim dipped headlights."
  17. Tideland Prius
    16,668
    An extension of "dipped headlights". Nice.
  18. Coast Cruiser
    2,267
    2,571
    Foggy this morning. Visibility was very low, and definitely foggy enough to require having the headlights on. I drove down the street flashing my lights at everyone. I can't believe all the incompetent California drivers!
    I saw at least a dozen Gen2 and Gen3 Prii's, and only ONE driver had their lights on. Multiple Prii's coming out of the dark like a little bugs...
    There is something seriously wrong with the Prius drivers out here. :eek: Are they afraid to spend 10 cents and turn the lights on?! They need to get off the road if they're going to be unsafe like that.
    RCO and Prodigyplace like this.
  19. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Headlight bulbs on a Gen 2 are notoriously difficult to change, they're either saving them, or the bulbs have gone.
  20. Prodigyplace
    12,710
    11,848
    Central Virginia
    Perhaps they were on but the sun has yellowed the lights so they are hard to see in the fog.
