How does Prius compare to conventional cars in driving dynamics?
Discussion in 'Gen 2 Prius Main Forum' started by Yury, Feb 4, 2008.
  1. Yury
    Yury New Member
    Toronto
    interesting, thanks.
    compared to 4 cyl perhaps yes, but not after driving 244 hp V6 :D
  2. Tideland Prius
    16,491
    it's 195/55R16.... OR 185/65R15. The latter is the same as a Corolla CE. (The S and LE models used 195/60R15)
    ohh ok. But the 08 models have dropped in price substantially. The 07 base model was $31,280. The 08 with extra standard equipment is $29,500. The extra equipment includes side/side curtain airbags, foglights, auto-dimming mirror, theft-deterrent system, Homelink integrated garage door opener, 16" alloys, euro suspension and larger rear spoiler.
    Plus you can get the $2,000 EcoAuto rebate and $2,000 PST rebate from Ontario. So take that into consideration.
    244hp? That sounds like an 05-07 Accord.
  3. icarus
    icarus Senior Member
    4,884
    976
    earth
    The prius gets on the freeway without being rear ended, it runs twistys like any other no performance car. If you want high performance it is there, but your mileage will suffer.
    I have come from a 911sc Porsche. Does the Prius compare? 4 Wheels and a windscreen! On the other hand 52mph @70 is nice. The 911 got about 12 @ 140! Prius carries 4, the 911 only 2, usually only me. Who wants to hang on in the twistys in the passenger seat.
    You'll love the Prius
    Icarus
  4. Yury
    Yury New Member
    Toronto
    Yep, that's what I drive.
    So the overall rebates would be 4000? I new about the PST rebate, didn't know about the second one.
    Yep, my mistake, 195/55R16 is what my vibe had.
  5. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi Yury,
    Well, that depends on the V6. If its 4 speed automatic, geared for speed, the Prius will do well against it up to 40 mph. If its geared like a VW, has a 6 speed DSG transmission, not at all. This is because of the wider gear range of the Prius than the 4 speed automatic. Which allows the engine to be at higher RPM's at lower vehicle speeds.
    Setting up the transmission for a quick acceleration takes experience with driving the Prius for good Fuel Economy. When one does that one lifts throttle and brings it back up to just cruise along. To setup the transmission for a quick accell, one just pushes the throttle beyond this point, confirming the engine has come on and that the FE is reading like 30 or so mpg, at a speed one can get about 50 plus. Knowing where that point is, is a skill developed for best fuel economy driving. And knowing how far the throttle will go up before the car speeds up is second nature after a while. The engine is now running at its highest RPM for the vehicle speed, which is the same as when one was running for FE, MG1 has reversed, and the car is ready for its best accelleration performance. I guess one can consider this like downshifting. Maybe they should put a downshift momentary button on the dash. But they didn't.
  6. Tideland Prius
    16,491
    Pretty much, yeah. That's another reason (plus the lower 2008 prices) that Toyota Canada sold 178% more Prius in Canada this past January (300 something, almost 400)
  7. darelldd
    6,059
    389
    Northern CA
    To put this into perspective, my all-electric, 1996 EV1 with 153 rated HP was faster to 60 mph than my high-pressure turbo, 250 HP 2000 Volvo T5.
    The differences are many, and it all depends on what you call "performance." In the end, cars are just transportation though! Once you get over that hurdle, the Prius is more car than most people need.
  8. patsparks
    10,664
    567
    Adelaide South Australia
    The torque of MG2 would test the strength of the crankshaft in the 244 hp V6.
  9. Yury
    Yury New Member
    Toronto
    my Accord is 5 speed auto.
  10. Yury
    Yury New Member
    Toronto
    You owned a EV1, wow.
    Well...the performance i am looking for is mostly short bursts of acceleration for merging or passing.
    Usually gas V6 would provide decent 0-60 times..But then I have always questioned the relevance of 0-60.
    For instance diesels are not very good in that respect, but i keep hearing that despite that they are quite driveable. I read that 160 hp diesel Jeep Liberty is not any worse that their gas V6 or maybe even better. Maybe there's something similar when comparing hybrids to gas engines.
  11. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    He only WISHES he owned an EV1... he leased one ;)
    0-60 time is pretty irrelevant unless all the other drivers are blind. The engine performance, power, acceleration have never been a problem for me. The only thing that makes me a little nervous sometimes is the TRAC kicking in if I'm accelerating from a dead-stop and turning into traffic.. that usually means the tires slip a little and TRAC cuts power a little to minimize slipping.
    That's not unique to the hybrid drivetrain, but I've never driven another car with traction control, so I can't compare experiences.
  12. Yury
    Yury New Member
    Toronto
  13. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    I had my first real occasion to flog the Prius, and have to say I was pretty impressed. I generally drive the Prius pretty sedately, really focusing on mileage. This is a big shift for me, as I've always been a pretty aggressive driver (trained in Boston & New York). I still am really, any time I'm behind the wheel of our WRX it all comes right back. Its one of the things I enjoy about the Prius, its been very good for my stress/blood pressure. Sort of like automotive yoga.
    Anyway, we were running very late for an appointment so I had to break out the WRX style on the Prius last night. Of course you really couldn't push it as hard as you could the WRX, but it responded with enthusiasm and never left me feeling like it couldn't keep up. I generally despise driving small crappy (often american) cars as I constantly feel like the car and I are not on the same page. Often I'll ask it to do things and its just not there for me. Its hunting around for what gear to shift into, or just plain off balance. Anyway, I've never experienced that in the Prius. It may not be lightening fast, or have go-kart handling, but it does what you ask it to. There are some tricks as a previous poster mentioned to getting things spooled up right to respond almost instantly. When you miss that, there's just a short delay kind of like waiting for the turbo to spin up on the WRX.
    As mentioned before the only time I've ever asked the Prius to do something and been a little surprised was cutting a left turn a little close and hitting some loose gravel causing the traction control to kick in. The car still re-composed it self and got out of the way in plenty of time but there was a disconcerting moment there.
    This morning I was back to regularly scheduled programming, but its nice to know the car is capable of that sort of performance when you need it.
    Rob
  14. Qlara
    Qlara New Member
    488
    The Prius' Hybrid System net about 110 hp output.
    It's still not a dragster, but for a sub-3000 lbs car which is adequate.
    I've driven less: 65hp....85hp smaller block before, still able to manage.
    Never break a sweat passing a semi on the highway over 70+ in my Prius, and its handling is like a normal sedan.
