How does prius identifies that oil maintenance is required?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kapaoke, Aug 29, 2013.
  1. kapaoke
    kapaoke Junior Member
    31
    I have had oil change about 5k ago now we are getting 'oil will require soon' sign .
    How does prius identifies that oil maintenance is required? Is it based on miles driven after reset of oil warning or something else? Originally manufacture recommended 5k .. now there is 10k recommendation.. Just wanted to make sure this warning is not based on millage.
    Regards
  2. Mike500
    Mike500 Senior Member
    2,593
    767
    It's just a miles trip counter. It says "service" until you reset it.
  3. kapaoke
    31
    so it does not look at oil quality or something like that? if toytota change recommendation to 10k why didn't they updated software to reflect correct warning?
  4. Mike500
    2,593
    767
    No, there are NO sensors or software other than counting the miles driven.
    Service is recommended every 5K miles. You do the oil change every other service interval.
    There is no "clock" timer, either.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    It is based on mileage. Should come up about every 10,000 miles.
  6. Steve terry
    Steve terry Member
    217
    Oklahoma
    I took my wife's Camry in for the 15,000 mile service and that means a tire rotation. The service guy looked at me and said the oil needed changed. I had to tell him that it is 5,000 mile tire rotation service. So, service does not mean oil change like it used to. Looks like some people need some IN SERVICE training.
  7. Steve terry
    Steve terry Member
    217
    Oklahoma
    Another good question is: with synthetic oil, does it break down and produce an acidic property after so long? As everyone has always heard. Change the oil at 5000 miles or 6 months. Some say it is because regular oil will start to produce an acidic property and harm the engine. But with all the new technology in oil and syntetic oil, does it still go bad over time like the old days or are we still brain washed by Jiffy lube 3000 mile 3 months gimic?
  8. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    You are all wrong. There is a little troll in the back of the car that only comes out when we are sleeping and checks the oil quality. If it needs to be changed, the light comes on. Then, he sneaks inside and fools around with the troll that turns the refrigerator light on and off...
    Jonny Zero likes this.
  9. Steve terry
    Steve terry Member
    217
    Oklahoma
    I did smell a dead troll in my car the other day. It got up to 105 outsine and I left the windows rolled up. He died a horrable death so now I have to rely on the service light.
  10. wheelsup
    wheelsup Member
    109
    24
    Raleigh, NC
    I thought the oil change interval has been moved to 10,000 miles with M1
  11. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    And everybody thinks it is a mouse...who knew?
  12. rfruth
    rfruth Member
    394
    Houston, Tx
    My Ford is the same, change oil message comes up at 5K - dealer says change oil & flush - both not needed except for dealers boat payment :LOL:
  13. El Dobro
    El Dobro A Member
    7,102
    3,282
    Newer models say "maintenance required".
  14. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    On the 2010, "oil maintenance required" comes up every 5,000 miles because back then when the 2010 first debuted Toyota required oil changes every 5K miles. As mentioned, newer models say "maintenance required," but I think it still comes up every 5K miles.
  15. El Dobro
    El Dobro A Member
    7,102
    3,282
    Correct.
  16. The Electric Me
    9,083
    5,801
    Yep, I was wrong. I haven't even put 5,000 miles on the vehicle yet. So haven't seen "the light". I'm getting close to my first 5000 miles, so I'll let you know if the light comes up for me.
    So I take it, instead of reprogramming or re- timing the appearance of the light Toyota simply took the word "Oil" off the light?
    I suppose that's easier than providing two lights...or reprogramming the timing.
  17. The Electric Me
    9,083
    5,801
    I'd like to edit my original "in error" post.
    But is anyone else having trouble with the edit function?
    Lately when I try to use it, the box just opens empty, and I can't enter any changes.
    Is it just my computer slowly dying? Or has anyone else noticed this problem?
  18. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Yes, people are required to take it in every 5K miles anyway (to keep the warranty) so the service advisor will know when it's time for oil change if they're clueless.
    I just tried it on an old post of mine and can still edit, but at least one member has reported this same problem.
  19. The Electric Me
    9,083
    5,801
    What's the tire rotation recommendation?
    Honda's maintenance light used to light up with specific alphabetical code combinations that would outline exactly what was recommended.
    Which was nice, but a little frustrating as what I found would be The Car was telling me to have the tires rotated, but when I'd take it to the dealer, they would "inspect" the tires and tell me it wasn't necessary. I finally had to insist they rotate the tires whether they visibly thought they needed to be rotated or not. For some reason, my dealership was very hesitant about rotating the tires.
  20. El Dobro
    El Dobro A Member
    7,102
    3,282
    Rotation's at every 5000, that's why the maintenance message still comes up at 5000 miles.
