How effective are the heated seats? The heated steering wheel?
Discussion in 'Prime Main Forum (2017-2022)' started by Husker4theSpurs, Aug 30, 2017.
  1. Husker4theSpurs
    Husker4theSpurs Active Member
    656
    128
    Papillion, Nebraska
    Hey guys,
    Was wondering how warm the heated seats get in comparison with some other cars you've owned? Same question for the heated steering wheel on the Advanced?
    We have an Acura MDX currently and the heated steering wheel is TERRIFIC, but our BMW heated steering wheel is just OK. The heated seats on both are solid.
    My old 2010 Prius's heated seats were just OK from what I recall. They were warm but not super warm.
  2. MNdriver
    MNdriver Senior Member
    549
    577
    Haven't had mine over winter yet. But should be able to report back in about, uh, 2 weeks.
  3. Ookies
    Ookies Junior Member
    Chicago Burbs
    Works very well... but not the entire steering wheel is heated..,had mine since January in chicago
    iPhone ?
    ruby likes this.
  4. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    The heated steering-wheel gets warm surprisingly fast... by the time I got to the end of the block.
    ruby likes this.
  5. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    On mine the wheel heater is a bit too much, I have to turn it off now and again.
    A kind of "pulse and glide" for proper temperature.
    jp
    ruby and bps like this.
  6. bisco
    52,878
    heated seats are hot! i feel like i wet myself, even on low. and it only takes a few seconds to heat up.
  7. john1701a
    12,840
    5,312
    58
    You've tried then in Prime?
    In PHV, the "hot" was just right for Minnesota.
    priuscatprimeguy likes this.
  8. bisco
    52,878
    just on my test drive. yeah, i suppose location matters. do you find them different than pip?
  9. john1701a
    12,840
    5,312
    58
    I have only experienced Spring cold so far, not the dead of Winter yet.
  10. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    And, the heaters draw the battery down a bit. They do reduce the electric distance run a few miles before the gasoline engine starts.
  11. john1701a
    12,840
    5,312
    58
    Seat & Wheel effectiveness reduces the need for cabin heating. A lower setting works fine when butt & hands are comfortable.
  12. bisco
    52,878
    probably less than the heat pump.
  13. bps
    bps Active Member
    304
    119
    Sounds exciting! ;)
  14. Cave Arnold
    Cave Arnold Member
    64
    60
    Lehigh Valley, PA
    I got my Prime Advanced in late January and winter continued until about mid April. It never got into the low teens or single digits, but it was in the upper teens several times. With my previous 2014 PiP I did not have heated steering wheel and would often need to wear gloves when driving in the winter on very cold days. Since I have had the new Prime I have not had to wear gloves and I find that the heated steering wheel works very well. I normally take about 1-2 minutes to get all setup before I start moving from the park position, but in that time I found that the heated steering wheel was nice and warm. I had seat heaters previously and those also worked well and the Prime's work as well as the PiP's so far as I can tell.
    My favorite Prime addition though is not the heated steering wheel, but the heap pump and the ability to use remote climate to start the vehicle heating for 10 minutes as I make my way to leave from work. It takes me about 8-9 minutes to walk from my office to my car so at the end of a cold day I just start the remote climate and by the time I get to my vehicle it is nice and toasty compared to the outside temps or the temp inside my car which is parked above ground on the side of "wind chill hill" as I call it. Don't forget to lock the vehicle or remote climate will not work. My 2 cents.
    ruby, john1701a and priuscatprimeguy like this.
  15. MNdriver
    549
    577
    Looking forward to trying that heat pump trick from my office window! Do the lights flash to let you know it started?
  16. john1701a
    12,840
    5,312
    58
    Advanced offers the option of starting the heater using your phone.
    kevins007 likes this.
  17. MNdriver
    549
    577
    Yep, I know - but just depressing the button on the key fob sounds 5 seconds faster.
  18. JMalmsteen
    JMalmsteen I love my Prius!
    287
    266
    Long Island, NY/Lancaster, PA
    I put the heated passenger seat on low, it worked fine. Compared to my vette which is our other car with heated seats, the Toyota ones seem better, but the vette seats are also cooled!
    How do you turn on the heated steering wheel?!?
  19. MNdriver
    549
    577
    It's a button the the right side of the steering wheel.
    JMalmsteen likes this.
  20. scm2000
    scm2000 Active Member
    164
    125
    I've had heated seats before in a conventional car and never noticed any less need for cabin heat.
