How have your replacement wheel bearing hubs lasted?
Discussion in 'Gen 3 Prius Main Forum' started by brianw, May 17, 2020.
  1. brianw
    brianw Junior Member
    28
    I see a lot of post on here about wheel bearing hub replacement, and brand loyalties. Experience tells me OEM lasts me on average 10 years or 150,000 miles based on my last 3 Prius’. One of my cars had Timkin as a replacement and all is good after 50,000 miles on them but I don’t have experience beyond that. Have any of you had your replacements fail, and if so what brand and how many miles? If no failure, what brand and how many miles have you gotten out of them so far? I’m considering TRQ for $65 each and a lifetime warranty with feedback that they last roughly 15 months approximately, with free replacement. My concern is I put about 40,000 miles a year on my car rather than 20,000 so I wonder if I’d only get 7 or 8 months out of them on average, and have the labor to do all over again. I’m hesitant to spend $260 or so each for OEM even knowing they often last 150,000 miles because I expect either a major failure of car replacement before another 150,000 miles. I know people like Tinken, and I have 50,000 miles on some of mine and seem to be a-ok so far, but believe they are made in China I’m curious how many miles people have on theirs. Just looking for your experience on how your replacements have fared. For me the labor factor isn’t too big a deal so I don’t want to spend too much more on Timkin if others haven’t gotten say 100,000 miles or so out of them. I have 2 to replace so I’d love to buy the quality OEM product, but I’m not wanting to spend the money on those right unless others have had really poor luck with Timkin or maybe TRQ. Not looking for opinions on brands, just looking for your experience so far with whatever brand you’ve used as replacements. Thanks for any feedback.
  2. ChapmanF
    19,050
    Maybe an advantage to hubs that flake out faster is they won't be as stuck when you have to change them.
  3. brianw
    28
    I was actually considering that. If they aren’t stuck on bad yet, replacement goes fast once you’ve done it before. My uncle used to have a car repair shop and cussed some products that lasted too long because they made his job harder.
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I put about 24,000 miles a year rather than 12,000 miles a year, the stock bearing never been replaced. In your situation, I would source another brand if they don't last for an entire year.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    I put Timken front hubs on our 2005 when it had about 260k miles. It's been at 299,999 for a yearish, and no problems.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    I put the cheapest hub assembly from rock auto on our old 2010 at 170k miles (don't remember the name and it was ~$60 for the drivers front) and it was doing fine at 30k miles when I sold it at 200k miles :).
    Put a Moog on the passenger front at 174 k miles and that was doing fine at the 200k miles sale;).
    The Moog was 2x the cost of el cheapo:cool:.
    But they seemed to do the job as I got 170k out of the oringinal hub assemblies(y).
    RMB likes this.
  7. brianw
    28
    It sounds like you’re implying that the OEM hub assemblies are Moog. I don’t believe this is the case. All mine have been have been stamped Koyo, the Japanese bearing manufacturer, which bought Timken I believe in 2009 or 2010. I haven’t looked at mine from my 2010, but assume they are Koyo also. If costs were the same I’d lean toward getting Koyo, with Timken my second choice since they may not be created equal but are at least owned by the same folks.
  8. brianw
    28
    I’m leaning toward buying Timken again, since many Timken hub assemblies seem to have Koyo bearings these days, since Koyo has owned Timken for so long. Hoping to get the OEM quality of the Koyo’s at Timken prices.
  9. spiralhelix
    spiralhelix Active Member
    255
    220
    Illinois
    At 150k I replaced the front left hub with a TRQ. Turns out the tires just needed to be replaced. I’m now at 248k (100k on the replacement) and no issues. I put on about 35k per year.
    I also replaced both front hubs on my truck with TRQ. One started to make noise and they sent a replacement for “free” (though I think I had to pay return shipping on the bad one) that was received two days later. Don’t remember the miles on it though. All in all I haven’t been disappointed with them.
    iPhone ?
    SFO likes this.
  10. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    No implications here;).
    Just evidence and data :).
    Pointing out that even cheaper hubs will last equivalently once the miles pile on(y).
  11. ChapmanF
    19,050
    Do I correctly understand the evidence and data to be:
    Original hubs: 170,000, 174,000 miles
    El cheapo $60 hub: 30,000 miles, possibly more
    Moog hub: 30,000 miles, possibly more
    Raytheeagle likes this.
  12. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Yup:).
    So I spent 2x on an experiment of quality and cost ;).
    Haven't talked to the new owner since we sold it last April (no need is good news), but my guess is they are still on there turning away(y).
  13. ttou68
    ttou68 Active Member
    351
    211
    I've replaced 2 front and 3 rear recently on 3 different Prius.. two 2010 and one 2005.
    All replaced with TRQ because I bought into their lifetime warranty because I usually do the repairs myself..
    Couldn't help you with durability because I haven't need replacing any up until now...
    However, everything I bought from 1A Auto have seem to be good quality with exception of a set of Eagle Eye Headlamps for Gen 3 Prius.
    It just didn't fit well with wider gaps then I like... I'm the type of person didn't like gaps more then OEM tolerance...
    And they claim there's nothing wrong with the headlamps, it didn't fit correctly is because they are after market parts, and it couldn't fit exactly due to OEM copy rights..
    I found that to be unbelievable, perhaps there are design difference but they should always have decent fitment..
    #13 ttou68, May 18, 2020
  14. brianw
    28
    I’ve personally never seen any evidence of Moog wheel hub assemblies on 2008-2015 Prius’, but I’ve only had three. Maybe a few got some due to a parts shortage, or maybe even an entire year but the hub assemblies Toyota Parts sells right now for 2010-2015 are not Moog. I have seen Japanese bearings in Korean assembled Moog hubs and I couldn’t say for sure if Moog uses Koyo bearings or makes their own in Japan. Moog is built in 16 countries so neither would surprise me.
    Anyway, what I did find was Koyo bought Timken in 2009 and the hub sold as genuine toyota is identical to that sold by Timken. I don’t know if the bearings in the Timken are branded Koyo or Timken but being owned by the same company I imagine they may be the same even if one is stamped Koyo and the other Timken.
    The first two pics are “Toyota” and Timken. Notice the identical “N” outside each stud, and the dull coloration of the studs. Identical. The third pic on the other hand is Moog. I see several differences in the Moog that don’t match the Toyota supplied hub. No “N” markings, shinier studs, coloration of the body of the hub between the mounting areas and a slightly different plastic mold used.
    If the toyota parts aren’t Timken, and are instead Koyo, they may be identical anyway being made by the same company. I even ran across a post from a guy working for a place that supplies Koyo and Timken and he says they sell identical dies to each for at least whatever they’ve sold them. Having found all that, I’m just going to stick with buying Timken from rockauto for half the cost of genuine toyota, figuring they are likely identical and if not then Timken has a good reputation so worst case scenario the hub is the same (aside from maybe sourcing the raw metals from different countries) and possibly the bearings used in the hubs might not be exactly the same. When I order the Timken I will post if the bearings themselves are stamped Koyo or Timken, but when i bought Timken for my 2009 Prius the bearings themselves were stamped Koyo, so hoping for the same.
  15. jimolson
    jimolson Member
    162
    63
    Indianapolis, USA
    I replaced noisy front wheel bearings on my 2006 and 2009 Priuses at roughly 100k miles. Are you guys saying that the problem of short-lived wheel bearings was not fixed by Toyota before the introduction of Gen III?
    Everyone in Toyota Engineering was probably too busy working to develop the high quality Gen III EGR system to tend to Gen II wheel bearing issues.....
    Prius Rising likes this.
  16. Paul E. Highway
    Paul E. Highway Active Member
    210
    131
    Hawaii
    Aloha!
    Getting mentally prepared for hub replacement and was checking on Amayama out of Japan. OEM hub is $192.71 plus $32.30 shipping but they also have the Koyo hub for $57.65 plus $43.32 shipping, roughly half the price.
    Anyone have experience with the Koyo hubs? I believe they make the OEM and also own Timken so curious what the Koyo branded product would be like. Looking for high quality at a fair price!
    PEH
    SFO likes this.
  17. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Which gen(s) received front/rear, and how are those TRQs holding up so far?
  18. ASRDogman
    ASRDogman Senior Member
    8,069
    4,092
    trq's suck! They only lasted 3-4000 miles for me. Front's and rear's.
    Don't waste your time or money on them. If you only drive a few thousand miles a year,
    it might be worth it, if you change them yourself.
  19. ttou68
    351
    211
    2010, I have not have any issues with any of them...
    SFO likes this.
  20. rjparker
    rjparker Tu Humilde Sirviente
    11,132
    6,982
    Texas Hill Country
    My Timkens looked exactly like the OEM. Including welds and stamps. Timkens are not cheap but save money over OEM.
