How hot is it in the midwest?
Discussion in 'Gen 2 Prius Main Forum' started by skyswordsman, Jul 26, 2012.
  1. skyswordsman
    skyswordsman New Member
    Saint Louis
    Its hot enough to melt rubber baby!
    I drive in MO, and where I work I do not have any shade to park in. We have been having bouts of 100+ degree heat, and it got so hot that it melted the handguard rubber from the trunk release. Is anyone else having this issue?
  2. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Hi Skys,
    There are several post's about the switch melting here on Prius Chat.
    The part # is 84905-47010 and can be purchased here Champion ToyotaWorld
    I did check stock with Mike @ Champion, he said they do have the item in stock. 713-943-7010
    For more information refer to these posts.
    2007 prius trunk hatch release rubber piece melted | PriusChat
    The price on the switch is $72.80 from Champion Toyota in Houston. You can order the switch online, and install it yourself.
    How to Replace the Hatch Opening Switch | PriusChat
    Good luck to you and I hope this info helps you.
    Ron (dorunron)
