How I Recondition Cells
Discussion in 'Gen 2 Prius Main Forum' started by tracy ing, Jun 19, 2022.
  1. tracy ing
    tracy ing Active Member
    384
    174
    wash dc
    Get ready for the dogpile of jealousy, I have seen all of this before :)
    JohnPrius3005 likes this.
  2. tracy ing
    384
    174
    wash dc
    By the way, the reason for that repeated discharge to 6 volts ?
    I have a reason for suspecting this was needed
    I never did before
    During this thread I executed that
    IT WORKED
    It was that step that got me to 6.5 Ah
    Go figure
    Step 1- Discharge to 6 volts at a 5 amp load
    Then, repeat at a 2.5 amp load
    Then, a 1.6 amp load
    Then, a 0.8 amp load
    Then, a 0.4 amp load
    Then a 0.20 amp load
    Then a 0.10 amp load TO 5.9 VOLTS.
    And I Lmao at the ridiculous assertion that cell reversal is possible using the above when posts on this site tell you to go lower or even ZERO lol
    R I D I C U L O U S posts here lol, seen it all before my friend, seen all of this before
    russia russia russia lol
  3. tracy ing
    384
    174
    wash dc
    And now, the LOGIC behind the repeated discharging, that I came up in the MIDST of this post
    I saw all these posts about going below 6 volts and some VOODOO happening
    I thought about it
    I REASONED that what was REALLY happening is these people were EXERCISING a portion of the module that was being neglected in other cycling attempts.
    It is NOT the area below 6 volts, it is the area 6 volts and up that will not come out under higher amp loads
    Why the repeated discharges ?????
    TIME
    What is really needed to FULLY RESTORE is a low low low amp load to 6 volts
    And that would take WEEKS (exaggerated)
    The FASTER WAY to a low amp discharge is multiple HIGHER LOW AMP DISCHARGES to bleed off that energy so WE CAN GET TO THE LOW AMP DISCHARGE TO 6 VOLTS
    AND WHY TO 5.9 VOLTS ON THE LAST STEP ????
    BECAUSE YOUR VOLT METER MAY BE WRONG AND OVER REPORTING AND 5.9 VOLTS IS SAFE AS YOU CAN GO TO 0.9 VOLTS PER CELL SAFELY AND THATS 5.4 VOLTS
    Hope this CLARIFIES things for you lol
    I AM SEEING A 13% INCREASE IN AH USING THIS STEP LOL
    It is simple Simon !!!!
    The Ah that I see come out from these repeated discharges, that are only released at low Amp loads, SUDDENLY start coming out at HIGH AMP LOADS when tested a second time , THEY ARE RESTORED TO USE BY LOAD and not HIDDEN.
    DUH
    #83 tracy ing, Jul 27, 2022
  4. tracy ing
    384
    174
    wash dc
    I love when "internet experts" challenge my results, after the results are known and proven. lol
    The PROOF as they say, its in my pudding, come eat some. :)
    P.S. The step 2 charge LOW until 7.1 7.2 volts, IMPORTANT,, make sure you do it, that's from industry not me.
    #84 tracy ing, Jul 27, 2022
  5. tracy ing
    384
    174
    wash dc
    docs.google.com/spreadsheets/d/e/2PACX-1vTl4JLzOw1nsapjoGlqDtTIHd9UMrgPD4_DH5R04nQcvznddF76PXzNqxjqzjgD3e-2jbhuPXRsd8IO/pubhtml
    multiple sheets in that, click sheet 4 to see live results
  6. tracy ing
    384
    174
    wash dc
  7. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    Impressive. Never let them get you down. If it works, it works :D
    tracy ing likes this.
  8. dolj
    dolj Senior Member
    8,656
    4,406
    Wellington, New Zealand
    Tracy, can you confirm for me - am I correctly understanding that in this step you are not charging between each discharge, but are restarting the next discharge with the lower load each time?
  9. tracy ing
    384
    174
    wash dc
    exactly !!!!
    we are trying to get all the electrons out of the plus 6 volts
  10. tracy ing
    384
    174
    wash dc
    what, your modules didn't come with a convenient fill plug ?
    and before you start... yes, i know, its brass mixing with potassium hydroxide, thank you.
    you know what that fitting is sized for ?
    air compressor lol :O
    #90 tracy ing, Jul 27, 2022
  11. tracy ing
    384
    174
    wash dc
    I special ordered this back in May 2022 after researching all kinds of plastic glues, this one is the best, I has a plan :)
  12. Tiamaybe
    Tiamaybe Junior Member
    2014 Prius c
    I know this is off the subject of this very in-depth thread, and I apologize. I’m a single mom trying to do this all on my own. I swapped out my 12V Battery in my 2014 Prius C. After getting it all hooked back up and panel back on, I realized I didn’t put the red plastic cap back over the positive terminal. Is ok to leave it like that? Or do I need to take the panel back off and put it back on? Thanks in advance for any help you can give.
  13. tracy ing
    384
    174
    wash dc
    not critical but for safety reasons I would go back and put it back on, it is there as a just in case, like something metal falls in there or someone who doesnt know the danger works in there and grounds a tool to that post while turning a screw or something.
    BillMelder likes this.
  14. tracy ing
    384
    174
    wash dc
    First, get all the power out of it so it is "safer" lol :O
    fyi there was 7/10 of an amp hour in the bottom end
  15. tracy ing
    384
    174
    wash dc
    Well, I am probably not near as smart as you, however...
    OH LOOKY, AT WHAT HAPPENED BY WAITING A WEEK TO RE-TEST, A PERFECTLY GOOD HIGH AMP HOUR MODULE THAT TESTED REPEATEDLY AS GOOD HAS PROVEN TO HAVE A HIGH RATE OF SELF DISCHARGE,
    MAN AM I GLAD I DID SOMETHING STUPID LIKE LET IT SIT A WEEK AND RE-TEST PRIOR TO PUTTING IT IN THE CAR AND FINDING OUT THE FIRST TIME I LEFT TOWN AND CAME BACK TO A BAD BATTERY THAT I HAD JUST SPENT WEEKS REBUILDING
    INTERNET EXPERTS, GOTTA LOVE EM
    (BY THE WAY I USED TO PRODUCE THE TEST SCENARIOS AND TEST SCRIPTS FOR GTE AND NORTHERN TELECOM BACK IN THE DAY AND HEADED THE Y2K TEST RESOLUTION AND COMPLIANCE FOR GTE GOVERNMENT SYSTEMS AS MANDATED BY THE SECURITIES AND EXCHANGE COMMISSION, I'M NOT A TOTAL TARD LOL )
  16. tracy ing
    384
    174
    wash dc
    Unsolicited derogatory opinions and comments are like butt-holes, everyone's got one,
    except Kim Jong-un, Supreme Leader of North Korea, it's a fact, google it, claim he has one in North Korea and you will be summarily executed.
    MAN I'M GLAD I'M TOTALLY STUPID AND LET THIS MODULE NUMBER 8 SIT A WEEK AND RE-TEST PRIOR TO PUTTING THE PACK BACK IN THE CAR
  17. tracy ing
    384
    174
    wash dc
    So I am recharging 8 one more time to check it, but it's futile, it's resting voltage just minutes after a deep discharge is 7.71 volts, that means it has one cell that has failed due to lack of water that can still provide all of its amp hours but not at the high 1c amp rate.
    I went back and checked, number 8 came from a bed of 15 previously tested and graded cells and was just inserted into this honda insight pack last week
    https://youtube.com/shorts/RmUE6fIQaOk?feature=share
    #97 tracy ing, Jul 28, 2022
  18. PriusCamper
    PriusCamper Senior Member
    13,476
    5,441
    Pacific Northwest, USA
    Can you please remind me again of the device that you're using to get these beautiful graphs of your module health? I think @alftoy answered this for me last time you posted a graph like this, but can't remember what happened to that link?
  19. alftoy
    alftoy Senior Member
    1,132
    520
    Saskatchewan, Canada
    West Mountain Radio - Computerized Battery Analyzer
    PriusCamper likes this.
  20. tracy ing
    384
    174
    wash dc
    Yep West Mountain
    LOL I just checked the IV DRIP it has gone down 5 inches in 2 hours, so it is working lol
