How I Recondition Cells
Discussion in 'Gen 2 Prius Main Forum' started by tracy ing, Jun 19, 2022.
  1. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    Now THIS will be interesting! Charging and reconditioning is one thing. "re-watering" is something else ;-) !!!!
    tracy ing likes this.
  2. tracy ing
    tracy ing Active Member
    384
    174
    wash dc
    LOL OH IT WILL START AT WATERING, AND BEYOND LOL
    I am going to answer several questions posed by man :O
    1- The reason for the IV Drip, I was able to get water in, but I had to shake it, screw that, gravity is my new employee. I want it soaked and saturated.
  3. JohnPrius3005
    423
    235
    Is there any info on the level of electrolyte which is present in a newly manufactured cell? Full? Small "gap"? Large "gap"?
  4. tracy ing
    384
    174
    wash dc
    There has been ZERO liquid in three I cut open that worked. They were "wet" inside
  5. JohnPrius3005
    423
    235
    Just dry electrodes? Or is there some kind of "wet paste" or absorbent material, just not free liquid?
  6. tracy ing
    384
    174
    wash dc
    Not much liquid in last 2 hours, then I sat it upright and LOT of air came out and it dropped 2 hours worth in the tube,. Then laid it back on its side
  7. tracy ing
    384
    174
    wash dc
    I believe its what ever liquid could wick into the material like an absorbed mat battery
    JohnPrius3005 likes this.
  8. JohnPrius3005
    423
    235
    Very interesting. If you get the chance or inclination drop me a contact email - [email protected] There are things I'd rather not discuss on a public forum. If not, no sweat. This is really cool what you're doing. Thanks for sharing.
    When you cut them open was any of the "material" wet, or isn't it possible to determine?
  9. tracy ing
    384
    174
    wash dc
    yep they were wet inside, just no free liquid
  10. JohnPrius3005
    423
    235
    So do you plan to drain out any "excess" before resealing? This is very cool stuff you're doing.
  11. tracy ing
    384
    174
    wash dc
    no, and then yes :)
  12. tracy ing
    384
    174
    wash dc
  13. Prius92
    Prius92 Active Member
    595
    122
    Iowa
    So now we are cutting open cells that contain potassium hydroxide, which is extremely caustic?
    I hope to hell you have the proper PPE for dealing with that stuff. It's pretty much the main ingredient in many drain cleaners.
  14. PriusCamper
    PriusCamper Senior Member
    13,476
    5,441
    Pacific Northwest, USA
    More than a decade ago @Britprius did this as a proof of concept. His work was easier to follow compared to this person's more chaotic posting habits. I find it interesting and wish I could learn more directly rather than just reading his posts. As for hazardous waste aspect of it, I'm thinking it's not too hard to do that fairly responsibly at this stage. But the real challenge is how too much fluid added could lead to going beyond spec for internal pressure and the module popping. As someone mentioned recently on here a student lost an eye when the Prius C pack he was grid charging started popping module tops. And with that much fluid added they might pop sooner or with much greater force or both. Be safe @tracy ing
  15. Prius92
    595
    122
    Iowa
    Most likely could of seen this in just a couple days, or is a week some magic number you came up with?
  16. Prius92
    595
    122
    Iowa
    Jeesh..how many AH was he charging at to pop a module?
  17. PriusCamper
    13,476
    5,441
    When you grid charge for balancing you charge all modules up to max capacity at super low amperage so the modules that are fully charged dissipate the low amp voltage as heat while other modules not fully charged have a chance to catch up. But if you don't get rid of that heat at a rapid rate the modules overheat and explode. That's why most professional rebuilders work in air condtioned facilities or simply don't work on pack charging once temperature is above 80'.
    You can read his comment here: Build Hybrid Battery Maintenance Gear For Under $100 | Page 5 | PriusChat
  18. Prius92
    595
    122
    Iowa
    That's a tad concerning, I've had my modules on a 500Mah and 650MAh charge for over 16 hours before (I do have it set to cut off at 7500MAh), and they are still cool to the touch when done.
    But my charger also doesn't apply current constantly, it goes up to whatever you set it to, then slowly back down and up, I think in about a 15 second interval between 0A and what you set it to.
    There's definitely a "sweet spot" at which the reaction at end of charge is quieted down enough where the current doesn't seem to cause much heat. I found that to be about C/10 (650MAh).
  19. tracy ing
    384
    174
    wash dc
    You mean this stuff...
    It's so dangerous, I bought it off amazon, I hope it doesnt do like a gun does and just jump off a shelf and kill someone, like guns do, you know, cause guns kill people, not the person holding it.
    lol man get a life, why dont you go back through the other one hundred posts here where people did this and JUMP AND SHOUT AND PAUL REVERE on those threads too lol
    Heres an idea, since you have time, go hit all the diesel and soap forums too and wave your hands around and scream lol
  20. tracy ing
    384
    174
    wash dc
    LOL AT THE TAG TEAM ABOVE YOU GUYS ARE A RIOT
