How important is it to buy and install a "Grid Charger"
Discussion in 'Prius v Accessories and Modifications' started by Eric "v", May 28, 2015.
  1. Eric "v"
    Eric "v" Member
    229
    45
    'Vegas, NV, Baby
    2013 Prius v wagon
    jzchen,
    I've installed LED lights inside my v and the very low battery draw they have will (hopefully) keep the dome or map lights from draining my battery if they are left on accidentally.
    jzchen and bisco like this.
    51,964
    great idea! any specs on wattage compared to oem's?
  3. kiwi
    kiwi Member
    246
    87
    New Zealand
    Last night update:
    Finished and tested repackaging Toyota's High Voltage NIMH Rescue Charger for Lexus / Highlander. It is suitable for any 288v nominal NiMH battery pack, either 40 x 7.2V or 30 x 9.6V. Topped up the 40 module pack in the storage room straight away. Beauty. Have limited number of those.
    Extremely small form factor - will upload photo on site this weekend.
    It draws 26 Amps from 12V DC. I use IBM 12V DC 60A Industrial Power Supply to power that, but in the field it can be used from the starter battery. Internal timer shuts off charger automatically to prevent depleting the source.
  4. christian cox
    christian cox Member
    115
    ohio
    This may be off subject but I had an experience with a max grid charger representative on ebay and I explained to him that I had built a homemade grid charger that’s charged off at 350 mA and I can use it on both my Honda insight generation one & in my Toyota generation 2 and I couldn’t understand why his Maxx grid charger for generation two priuses couldn’t be used on a GEN three anyway apparently the guy got mad and said he was blocking me from all future transactions with his company and I hadn’t even made a purchase yet. That’s a little strange
    Air_Boss and bisco like this.
  5. G4G
    G4G New Member
    See what Dr. Prius shows. Way up from 42% to almost new condition. I think the discharging is almost as important as the charging.
    My fan also badly needed cleaned.
    This Prius is new to me and I didn't want to go through the hassle of swapping cells.
