How is A/C consumption in Prius?
Discussion in 'Gen 3 Prius Main Forum' started by MansTer420, May 26, 2013.
  1. MansTer420
    MansTer420 Junior Member
    119
    Every time when I fill up the tank it says I have about 540 miles to go.
    but in reality, I always end up getting 450-470 miles instead.
    thats about 80 miles shortage.
    My driving behavior doesnt hurt the MPG because Im getting around 51 mpg commute which is about 30 miles round trip in LA.
    So I figured it definitely has to do something with a/c.
    SAMSUNG-SGH-I317 ? 2
    52,862
    you're filling up way too soon, there's plenny of gas left.;)
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    If it was the AC, it would show up in the MPG.
    I'll guess you are filling up ~ 10 gallons each time. Since your meter reads 51 mpg and we know it is about 5% optimistic,
    you can expect
    10 * 51 * 0.95 = 485 miles between fill-ups.
    I don't know why the car calculates 540 miles till empty right after a fill-up. Perhaps it thinks you are going to use 11 of the 11.9 gallons available ? :p
  4. MansTer420
    119
    well I fill up the tank when the gas light comes on.
    and where it says how many miles to go before gas station becomes empty.
    everytime I fill up the gas I get about 9.4 gallons
  5. SageBrush
    11,627
    2,533
    Southwest Colorado
    9.4 gallons * 51 mpg/gallon * 0.95 fudge-factor-for-inaccurate-gauge =
    455.43 miles.
    Sound about right ? Just realize that ~ 2.5 gallons are unused when you fill-up. So if pressed, you can easily drive another 100 miles.
  6. MansTer420
    119
    even though it says I have less than 5 miles to go?
  7. SageBrush
    11,627
    2,533
    Southwest Colorado
    yup
  8. MansTer420
    119
    hm... so I should just push it little more.
    im just afraid to get stalled on the road.
  9. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    I think you should continue to do what you do, running one of these things out of gas can be a pain, I think that's why the guage and the computer turn that flashing bar on with a couple of gallons left in the tank.
  10. bisco
    52,862
    it's interesting that it keeps resetting to 540 when you fill up, but ends up close to zero when the light comes on. i thought the top number (which is an estimate based on your mpg history i think) would start coming down with each tankfull so you would have a more realitic idea of how far you can go. it sounds like it starts out taking the safety allowance into consideration, but at some point, adjusts so you're near zero when the light comes on.
  11. SageBrush
    11,627
    2,533
    Southwest Colorado
    Yep, that part of OP's story is inconsistent with my experience driving both the CTh200 and a Prius vagon. So far as I know, these two cars have the same innards as the G3 Prius.
    OP did not say it is particularly important to him to drive more miles on a tank; I think he was just wondering at the discrepancy. There is not doubt though that a substantial reserve of fuel is still in the tank when the meter says '0 miles left.' Since most of my tanks this time of year end up about 52 - 54 mpg on the meter, my trip meter usually tells me I have low 500 miles left after fill-up. In pursuit of cheaper fuel, I not infrequently run past the '0 miles left' warning at least 25 miles and up to 50 miles without a concern.
  12. bisco
    52,862
    i do the same. and my dte starts around 510 and when the bar blinks, it is around 10. and i go about 500+- on 8.0 gallons, so it's pretty accurate.
  13. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Toyota don't want you to empty the tank which is what you would have to do to get the mileage from a full tank the Prius calculates.
  14. SageBrush
    11,627
    2,533
    Southwest Colorado
    That makes no sense, and does not match what I see every tank.
  15. MansTer420
    119
    so it is okay to drive 50 miles more when left over miles reaches 0..
  16. bisco
    52,862
    it's okay, but it's never a good idea.
  17. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    I do.
    My second tank I went 534 miles with a indicated MPG of 55.6. (Mine is optimistic by 2.6mpg)
    I was only able to add 10.17 gallons to a 11.9 gallon fuel tank leaving me to believe I had 1.73 gallons of "reserve".
    Travis
  18. spoolinq
    spoolinq Junior Member
    23
    2019 Prius Prime
    I commute to and from downtown LA and always drive 40-60 miles after it says 0 miles left. I normally fill about 10.4 gal and have at least 600 miles per tank.
  19. MansTer420
    119
    thats about right because I fill up the tank at 460 miles and it drinks about 9.4 gallons
