How is Prime connected to the interwebs?
Discussion in 'Prime Technical Discussion' started by davidtm, Mar 15, 2017.
  1. davidtm
    davidtm Member
    180
    TJ'ville
    Per the title, how does the car receive data from the internet, such as software updates, and specifically, how is it connected to the phone app?
    TIA
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
  3. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Bluetooth, through the Entune Application on a cell phone.
  4. davidtm
    davidtm Member
    180
    TJ'ville
    Hmm, so since I usually turn BT off on my phone when I'm home, I would need to no longer do so . . .
  5. Lee Jay
    5,850
    4,036
    It only needs to be on when you're in the car and the car is on.
  6. davidtm
    davidtm Member
    180
    TJ'ville
    Well, except for changing charging settings, pre-operation of Climate control, etc.
  7. Lee Jay
    5,850
    4,036
    On the Advanced, those features are done through a subscription to "Safety Connect", for which the car has its own connection.
  8. davidtm
    davidtm Member
    180
    TJ'ville
    Thanks! I see that's free for the first year, then almost $12/mo thereafter. I'd have to decide if it's worth it.
  9. Lee Jay
    5,850
    4,036
    It's free for the first three years on the Prime Advanced.
    JacksonMs and davidtm like this.
  10. CharlesH
    2,798
    1,166
    Roseville, CA
    The Advanced has its own cell phone for Safety Connect (emergency response) and the "Advanced" Entune Apps (such as charge management, vehicle location, remote climate control). This phone is NOT used for the media Entune applications such as Pandora. For these, it uses a Bluetooth connection to the Entune application running on your smartphone, and thence to the Internet. The navigation system uses HD Radio data for traffic info, which comes over FM.
    BTW, what are "the InterWebs". I know about the Internet. I used it when it was still a Department of Defense research project called "ArpaNet". I know about a popular service that runs over the Internet, which is called World Wide Web (www). But what is this "InterWebs" thing?:confused:
    #10 CharlesH, Mar 15, 2017
    GSK, java007md and rbdigital like this.
  11. davidtm
    davidtm Member
    180
    TJ'ville
  12. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    A surprising number of folks never gophered or kermitted, and think the web is all the network there is.
    Gopher (protocol) - Wikipedia
    Kermit (protocol) - Wikipedia
    Bob Comer and Prodigyplace like this.
  13. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Maybe I'm out of date, but I don't think it does software updates. I think you have to go to the dealer for that. Usually "by invitation only". ;)
  14. CharlesH
    2,798
    1,166
    Roseville, CA
    There are a bunch of different software components. I believe that updates to the Entune media apps are done online, when you connect to the media apps (like on the first generation PiP). Updating the core display software is done at the dealer. Map data is now on an SD card, I think. My apologies if I have this wrong.
    There are still lots of other Internet services in common use "under the cover", but they are usually either used internally (like DNS) or wrapped by an HTTP/HTTPS wrapper for the user interface. Thus, the misunderstanding of Internet = Web.
    #14 CharlesH, Mar 15, 2017
  15. davidtm
    davidtm Member
    180
    TJ'ville
    Any idea what cell network it uses?
    SM-T530NU ?
  16. CharlesH
    2,798
    1,166
    Roseville, CA
    I am pretty sure (but not 100%) that they use Verizon. I am not sure which technology they are using. (CDMA/1x or LTE). Since they don't use it for media streaming, they only need voice and low-speed data for the telematics, for which CDMA/1x is just fine. Unless the cell phone is LTE-capable, it is going to have a problem after Verizon turns off its CDMA network, currently scheduled for December, 2019. AT&T has already stranded GSM-only devices.
    priuscatprimeguy and davidtm like this.
  17. Tideland Prius
    16,683
    That'll be a problem if the cars are equipped with 3 years of Safety Connect. One would hope it's 3G at the minimum even if it's just voice and low speed data.
  18. DavidA
    2,349
    1,825
    Chicago western burbs
  19. CharlesH
    2,798
    1,166
    Roseville, CA
    Unlike the at&t/T-Mobile 3G infrastructure, Verizon 3G (EV-DO) does not not support voice. It is data only (the "DO" in EV-DO). If you want want voice on Verizon, it is either CDMA/1xRTT or LTE.
    Tideland Prius and Bluegrassman like this.
  20. Captmiddy
    Captmiddy Active Member
    225
    204
    Massachusetts
    When I talked to Toyota about a problem with our safety connect features, they said that it was Verizon, although I didn't ask if it was a CDMA or LTE connection. I should have asked but didn't think to. That said, last time I tried CDMA devices did not work in my front yard but LTE devices did, the car definitely gets and sends signals from my front yard so my guess is that it may be LTE given the horrible reception for CMDA in my yard normally. But it has been over a years since the last person was in my front yard fuming about their cell service not working on an office supplied cheap phone so who knows maybe Verizon updated some tower. My cell phones are ATT so can't really test out the theory.
    Tideland Prius likes this.
