How is the C at accelerating onto freeway?
Discussion in 'Prius c Main Forum' started by horseladyjune, Jun 9, 2013.
  1. horseladyjune
    horseladyjune Horseladyjune
    27
    Paradise, Ca
    Hi everyone:) ,
    I am at lease-end time on my original Prius, and unfortunately since I have
    no down payment, I cannot get the original Prius model again. The payments
    would just be too high, so I am considering a C with lower payments, but am
    concerned about the acceleration onto freeways because in my current Prius I have
    the option to use the Power mode for quicker acceleration. Does anyone have trouble
    accelerating onto the freeway?
    I will be going in to try one again next weekend, so I will try it then, but just wanted to
    hear opinions.
    Thanks,
    June
  2. X HCH2
    X HCH2 Member
    119
    38
    Upstate SC
    The C will surprise you with acceleration when you floorboard it. Eco mode or not, you get full power at WOT.
    I don't think you will have a problem merging into traffic.
    X
  3. 1911Tex
    1911Tex Junior Member
    57
    17
    2013 Prius v wagon
    Not a problem !
  4. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    ~.5 seconds difference to 60.
  5. Emily Allerton
    Emily Allerton Junior Member
    86
    Rhode Island
    The C doesn't like to go fast as some other cars do....my old Celica felt like it was always raring to go!
    But if you punch it it goes.....I merge onto highways a couple of times each weekday for my commute and I am very pleased with the C....it kills your mpg but I am too impatient to care!
  6. citroenjohn
    citroenjohn Active Member
    139
    103
    Mid-Michigan
    Absolutely no problem, in all merging situations with any car, just pay attention to traffic and plan ahead. My other car is a Citroen 2CV with a whopping 602 cc; 29.5 HP engine. The Prius C is way faster than the Citroen 2CV, yet both cars merge onto highways easily. Citroen used to advertise that their 2CV's 0-60 time was "the same day". The Prius C can handle any modern traffic condition, it's a great car.
    ChinchillaGirl likes this.
  7. james cook
    james cook Member
    145
    36
    Louisiana
    your mpg with drop like .1-.5 if you have to go into the red PWR zone..which you will.
  8. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    Depending, of course, on how long you are in the pwr zone and how long your trip is.
  9. horseladyjune
    27
    Paradise, Ca
    Wow, thanks everyone for all the responses & so quickly, too...
    I knew I could count on Prius Chat for help:)
    June
  10. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    I believe you got the answer you needed. What really surprised me is the passing power the C has when "floor boarded". I can pass, from 60-80, very easily when I stomp the pedal. I like it. Have not driven it over 85 yet.
    Dan
    WE0H likes this.
  11. james cook
    james cook Member
    145
    36
    Louisiana
    this car starts wobbling at 85. I pushed it to 100 in a 70 for 3 miles straight...but it was kinda windy outside...
  12. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    There's no doubting that once you've jumped off the line from a standing start, the c is not the world's fastest accelerator by any means, but it has plenty to get you ready to merge at freeway speed without any concern. This said, I have certainly noticed that if you are cruising along at steady speed and then want to accelerate and put your foot down, the electric motor does give you that little instant kick that allows you to make a clear and emphatic move, which to me is the critical factor in traffic. It was something I really noticed when I was driving my mother's Corolla for a day - although it clearly has more grunt, when I went to make an overtaking manoeuvre it was noticably slower to respond, not helped by having to take a split second to change down a gear.
    minkus, WE0H and ztanos like this.
  13. WD0AFQ
    619
    152
    Dexter, Mo.
    I did not believe I could live with this car so the first thing I did on a test drive was floor it. Told the salesman to hang on, ha. It did impress this old hot rodder from way back. Not like flooring my 65 Mustang but sufficient to do anything I want. This car is a MPG getter. I have other vehicles to hot rod.
    Dan
    WE0H, minkus and ftl like this.
  14. brucepmiller
    brucepmiller Member
    150
    73
    Michigan
    I put a chassis stiffener brace on mine and it made a big difference.
    WE0H and james cook like this.
  15. Farfle
    Farfle Member
    69
    44
    Yeah that's one of the things that initially worried me too when I took it out on a test drive. I noticed it didn't seem to have the power that a normal car does. But I was mistaken! Really, I think it's because the throttle peddle has a lot more give to it compared to a regular car. You can push this thing a lot further down without getting the power you'd normally expect from a car. But if you push it all the way down, then you get quite the surge. So keep that in mind if you decide to test drive one of 'em.
    minkus likes this.
  16. Rob.au
    960
    441
    Sydney, Australia
    i-Tech
    Agreed... I've only pushed the pedal all the way down a couple of times and I never quite expect to get what it gives.
    minkus likes this.
  17. cyeremian
    cyeremian Member
    142
    27
    SF Bay Area
    Don't forget you have the electric motor going with the ICE. The electric motor has instant torque no matter what speed. It's a blend and the power and acceleration is different from a non hybrid. It's pretty awesome. Take it up a hill, not gutless at all!
    WE0H and minkus like this.
  18. ewaboy
    ewaboy Active Member
    693
    205
    Hawaii
    Yep - the electric motor doesn't have sustained torque but it's near instant. A former coworker's husband is an electrical engineer and that's the first thing he asked me about - said electric motors respond incredibly fast. My wife's Honda Fit "feels" quicker but the C is "smoother" - her words - while still being quick.
    YMMV
    cyeremian likes this.
  19. cyeremian
    cyeremian Member
    142
    27
    SF Bay Area
    again, take it up hills and it will surprise you! A typical small 4 cylinder engine takes time for power to generate as the RPM climb. By that time you are feeling like, "Am I going to make it up this hill?" Not with the C, I went up a few hills the other day and was pleasantly surprised how it climbed!
  20. Rob.au
    960
    441
    Sydney, Australia
    i-Tech
    I can't say that the c's hill climbing is much of a selling point IMO. It will do it, sure, but compared to my previous car you do need a little patience on a decent mountain pass. Even just coming out of our Cross-City Tunnel in my old car I would do the whole thing at the speed limit of 80 km/h and the car wouldn't blink. The c could do that, but it sure doesn't want to and I don't force it to. These days I hold it to the top of the ECO area on the HSI and allow the speed to bleed off and by the time I near the top I'll be nearing the 60 km/h limit that applies after exiting the tunnel.
    Out of the city on some real passes I have to forget about the ECO area and I find the car will find a lower speed it's happy to maintain for the climb, which I tend to go with for a happier c.
    This is quite different from accelerating onto a freeway though.
    minkus likes this.
