How long can I idle in maintenance mode?
Discussion in 'Gen 2 Prius Technical Discussion' started by mattbatson, May 3, 2019.
  1. oil_burner
    oil_burner Active Member
    249
    126
    my advice (I've done the sleeping thing a lot)
    -you must have a CO alarm, battery powered. Don't kill yourself for the sake of sleeping in a car to save a few bucks. they're $10-15. Exhaust 100% makes it into your car through leaking exhaust joints, wind changing direction, etc. If you think there is no risk then go ahead and play Russian roulette to save 10 measly bucks.
    -I always park facing the wind. The air intake is at the windshield you do not want the wind at your back. Check the exhaust is clear.
    -new engine mounts help tremendously with the start/stop judder, as does putting in marvel mystery oil in the gas to clean the injectors and smooth out the idle.
    some other info:
    -AC runs off traction battery not the 12V, so hooking up extra 12V batteries, or putting a charger on the battery does nothing to prolong the start/stop intervals from personal experience.
    -strangely enough maintenance mode allows you to rev the engine, but after about 3 mins of this the engine will shutoff, presumably because it thinks there is a fault with the drive by wire gas pedal.
    mattbatson likes this.
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Really?
    https://www.google.com/amp/s/amp.freep.com/amp/1058296001
  3. ChapmanF
    19,006
    Looks like I mistakenly gave Gen 3 info in #7. Gen 3 has two different inspection modes, one for nonstop idling, the other for trac inhibition. But checking the Gen 2 manual, it's just one mode that does both. Sorry for the noise.
  4. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    So I bought a CO detector
    Still camping till Friday...
    Have it sitting on the dash
    I went back to running it in normal mode and seems to be ok for now
    Believe it or not I find less movement with it in park but no parking brake on
    I would think tighter engine mounts would transfer more vibration to the chassis ?
    I have been using MMO for decades
    Thanks for all the responses
  5. landspeed
    landspeed Active Member
    387
    210
    NZ
    2003 Prius
    Glad it is working out! Another reason to get a CO alarm that I thought of; if you were parked up and asleep and an old car, without a cat, parked in front of you idling, you could get a dose of CO if the wind etc was just right / wrong; this would even be the case if you were using the mod by Hobbit where you run the interior fans with the rest of the car off!
  6. oil_burner
    249
    126
    new engine mounts prevent the engine from rocking when the starter motor turns over, I filled my lower engine mount with PU glue because I couldn't find one locally, it made a huge difference. My car used to rock backwards several inches each time the car started.
  7. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    I actually used to fill the engine mount voids with urethane on my other cars in the past...street and race
    Good to know
    I’ll put that on my list
  8. Briana Giselle Jauregui
    Briana Giselle Jauregui Junior Member
    South Pasadena, CA
    JESUS CHRIST!!!!!!
    THANK YOU SO MUCH!!!!!
  9. Surge Lord
    Surge Lord Junior Member
    17
    Ontario
  10. ChapmanF
    19,006
    Funny ... between 4:54 and 5:02 he spends 8 seconds mentioning A/C use while parked, then moves immediately on to say "the most common reason batteries can wear on anything from cell phones to cars" is to "let a battery sit for a long long time and don't charge it." Which is true, and there have been a lot of pandemic-battery threads about that,but he kind of moved right on without finishing the thought about parking and A/C.
  11. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
  12. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    On second thought I don’t think the G2 charges the hybrid battery in inspection mode.
    It disables traction and the battery charge meter disappears on the mfd so a
    Little suspicous it may not be charging the battery. Not sure so it should be tested if it’s not charging if you plan on using it for a long time.
    I never ran it more than a few minutes in inspection mode.
  13. ws309
    ws309 Junior Member
    22
    ventura
    I was in maintenance mode for 3 mins and it stopped running and stalled out. I dont get it
