How long can Prius C be idle?
Discussion in 'Prius c Main Forum' started by PriusCee, Apr 14, 2023.
  1. PriusCee
    PriusCee Junior Member
    Washington
    2015 Prius c
    I inherited a 2015 Prius C and the 12V battery went flat about a month ago. How long can I let the car sit idle? Will being idle for an extended period of time ruin the hybrid battery set? Thanks.
    52,785
    there's no exact time. more than a week or two, and i would put an inexpensive maintainer on the 12 volt.
    for the hybrid battery, it depends on age and health. i would start to be concerned around 6 months, and more concerned if it were a regular thing, like a vacation home or some such.
    these cars like to be driven
    Pri3C likes this.
  3. Leadfoot J. McCoalroller
    8,271
    7,775
    Pennsylvania
    2018 Prius c
    Ones and Twos can sit longer due to basic ignition keylock systems. Threes and Fours don't last as long because they use smart key systems.
    Endurance slides with age and temperature.
    The hybrid battery has a finite lifetime, idle or used.
    From an economic standpoint, the best you can do with a Prius is run the wheels off it from the moment you inherit one until the day before it becomes a money pit. For that one? You're probably good through 2025 whether you drive it or not.
