How long has your original 12v battery lasted?
Discussion in 'Gen 3 Prius Main Forum' started by sardog, Jan 20, 2020.
  1. 46mike
    46mike Junior Member
    Rochester NY
    Still dealing with Chipmonks loving interior of my Prius
  2. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    About 8 years and 10 months @ 150k miles.
  3. Fostel
    Fostel Member
    99
    31
    Kent, England
    Excel
    I am at 86k miles. The battery is 7 years old (maybe 8). It's the smaller 35 Ah version and recently sits low around 12.2-12.4V
    I was going to get a new one but instead, I will try to add some water and charge it properly. Looks like 2 more years is doable.
    On the other hand, I am going to do brake fluid change and the old battery may not be good enough with the IG-ON for that long.
    Also, it looks like I am losing mileage because traction battery got drained to charge the 12V so it may not be worthwhile.
    Plan B is to install a 55 Ah deep-cycle battery.
  4. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    You could hook up your charger as you do the brakes.
    Should be enough to even charge the battery. It won't take 4 amps for the brakes,
    at least I don't think it will take 4 amps for the brakes....
    Fostel likes this.
  5. tonynap
    tonynap Member
    43
    38
    NY
    P.S. The aftermarket replacement lasted just 2.5 years.
    I did keep the OEM after I replaced it. It powered a small; inverter during a couple of power outages. It ran a phone charger, a coffee machine, and a lamp.
    It is an excellent battery.
    chinarut likes this.
  6. MGpwr
    MGpwr Member
    Not far (enough) from Asheville, NC
    Business Edition
    I've got two of the original Yuasa, one from a 2006 and one from a 2009, they've been powering one of my UPS for a
    couple years now.
  7. Steves895
    Steves895 Member
    48
    68
    Concord, NC
    2015 Gen 3. Replaced battery two weeks ago at 123,500 miles, with OEM battery from Toyota.
    ASRDogman likes this.
