How long is too long to leave it running?
Discussion in 'Gen 4 Prius Main Forum' started by petercrow1984, Jul 3, 2017.
  1. petercrow1984
    petercrow1984 New Member
    Vietnam
    I know the Prius works more efficiently after 10ish minutes of driving, and I know that it's a great idea to link your trips together to save on gas.
    So, let's say I'm driving on a three-hour trip and I stop at a rest area. Should I leave the car running, lock it with the key, run to the rest area, and then get in and just drive? Or should I shut it off and then restart when I get out?
    OR - what's the time cut-off for leaving it running. Is it efficient to just let the battery drain like that?
    Then again - what if I leave the heat on. Or the A/C?
    5 minutes? 10 minutes? 20?
    52,878
    welcome!
    just treat it like any other car. there's no point to leaving it running when you're not using it. and if you do need it, there's no cut off, just don't run out of gas. some people sleep in it overnight, with the havoc going.
    all the best!(y)
  3. Prodigyplace
    12,720
    11,852
    Central Virginia
    If you know you are stopping briefly, you might want to leave it running to keep the climate control on.
    I did that a couple of times on the weekend when we parked and had a dog in the car. I kept the AC on and car in READY mode. Once I stayed in the car and once I left the key in the car whil I was outside, near by.
  4. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    A word to the wise, always consider the security of your vehicle while you are away from it.
    'LectroFuel, wrprice, bisco and 2 others like this.
  5. Prodigyplace
    12,720
    11,852
    Central Virginia
    Yeah. Both The time I was outside, the only people around were me, my wife, and one other person we were talking with.
    RCO likes this.
  6. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I've only left it maybe 10 minutes, key locked, on a couple of very hot days, but it's been in a fairly secure area.
    Check whether your Daytime Running Lights are off, which could be a hint to the unscrupulous that it's running still. If I pull up after driving and lock up, they remain on. I have to POWER OFF, then, with the brake on, POWER ON and they stay off. (Depends on which country you are in - I don't think that happens in USA for instance.)
    RCO likes this.
  7. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    ... and the liability incurred if something were to happen as a result.
    RCO likes this.
  8. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    It only takes a fraction of a second to restart it, but given the Florida heat I sometimes run into my house to grab something and leave it on in my driveway for just a minute.
  9. William Redoubt
    William Redoubt Senior Member
    1,228
    1,174
    Coronado Island, California
    No havoc when I keep my AC on 72 when car camping. :) It's all sweet dreams! No sweat!
    RCO and kithmo like this.
  10. Kramah313
    Kramah313 Active Member
    411
    326
    Dallas, TX
    You aren't going to take much of a hit turning it off because the engine temp isn't going to cool down past the final stage warmup temp where it is in warmup mode (145 F) in just a few minutes (normal operating temp is 195 F, when the engine is on). It seems like it will still wait about one minute before it will go into EV if you are going more than stopped but that's it. Once it finishes that little check it will operate as normal. I'd prefer that to letting the traction battery run down idling.
    Now if you want the a/c or heat on that's a different issue.
  11. Mendel Leisk
    42,364
    I almost don't understand the question. I guess, I completely don't understand the question, lol.
    I'm gonna vote zero time left running.
    syncro87 and RCO like this.
  12. alanclarkeau
    7,045
    7,593
    Maybe next time it's over 40C degrees, you might be tempted to.
    William Redoubt, RCO and Mendel Leisk like this.
  13. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    In the UK it's also illegal to leave your vehicle running unattended, unless it's on your driveway. Insurance won't pay out if stolen whilst left running, although they would have trouble proving it was running if you have the keys in your pocket.
    Mendel Leisk, RCO and Prodigyplace like this.
  14. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    .... But not the fob sitting in the cupholder. :cry:
    kithmo and Prodigyplace like this.
  15. liquidtenmillion
    liquidtenmillion Active Member
    261
    194
    Easley, SC
    I leave it on sometimes if my wife is in the car, or if I will be gone for less than 40 seconds and nobody is around(I will leave it on if I forgot something inside the house)
    But other than that I turn it off and then back on. It stays warm for a while and it will not go through the warmup cycle again unless the engine is below a certain temperature.
    Gen 4 is even more aggressive about this, I find it does less warm up cycles. If it is 95 degrees outside for the first run of the day it will completely skip the warm up cycle the engine won't turn on until I go above the eco line. If I come back from the grocery store and turn the car back on I can st there for 20 minutes before the engine turns on, and that is for charging not for warm up.
    My gen 3 would still do the warm up cycle in both those situations.
    RCO, Kramah313 and bisco like this.
  16. CoastRider
    CoastRider Active Member
    305
    397
    Off into the sunset...
    I was re-reading my 2016 owner's manual (online version) and falling asleep... but somewhere around page185 or so, I don't recall the exact page number, it said the power will be shut off after 1 hour, when parked.
  17. Kramah313
    411
    326
    Dallas, TX
    This is usually 12V power after the car is off, like if you leave the radio of a light on it will cut power after an hour to protect the 12V battery. Our Honda Odyssey does this also, it always makes drive in movies fun. I don't think this applies if the car is running though.
    RCO likes this.
  18. Mendel Leisk
    42,364
    Yeah I suspect the car will run till it runs out of gas. I don't get this, and it's techinically illegal in a lot of areas. I kinda go into a slow burn, when I see folks sitting in their bubbles, catching up on Twitter, while their engines and fans whir away, pumping heat and fumes into the outside air.
    RoadNoise and Prodigyplace like this.
  19. Prodigyplace
    12,720
    11,852
    Central Virginia
    In my case it was for a short while both times and I do not think the engine even ran during those times since the AC is electric.
  20. Mendel Leisk
    42,364
    Yeah, but there's no free lunch: ultimately the engine ran more, to recoup the dropped battery charge.
    I AM a luddite, I know it. For me a car is about getting places, without bugs in my teeth, but that's about it.
