How long should 12V battery last in accessory mode?
Discussion in 'Gen 2 Prius Main Forum' started by holysmokes99, Aug 24, 2015.
  1. holysmokes99
    holysmokes99 New Member
    Victoria
    Thanks for the info and advice, Chap. I'll dig out our trickle charger buried in a box somewhere. Anything to look out for there? How "smart" does it need to be?
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    Yeah, so if you need to run accessories and stuff off the Prius, do it in READY while parked. Even though it will drain the high traction battery, the motor will kick on and recharge it.
    Also, if that 12v you have looks like the original that came with the car, which wouldn't be a surprise because its only designed to power up the ECU and therefore would last a very long time, I would still suggest replacing it. Funky stuff starts to happen when the 12v battery's charge drops too low.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    It is true that several parts of the 'video game' that is the Prius are a sloppy emulation of 'real' cars.
    There is no alternator, so your headlights do not get brighter when you rev the engine up. One section of the inverter converts 201 volts DC to 12 volts DC (actually about 14.4, so it can charge the 12 volt battery) This is unlike other cars in general where the engine is much more involved in making 12 volt electricity. (alternator, voltage regulator, etc.) Because the 12 battery never runs a starter motor, it can be smaller than usual for a car but this also means the Acc mode lasts a very short time and leaving the dome light on can drain the battery before dawn. (Another issue, how good are you at recognizing a dead or dying battery when it never makes the slow starting noise?)
    I like this guy:
    (15:15 to 18:00 explains the 12 volt charging)
    WilDavis likes this.
  4. CrazyLee
    CrazyLee Member
    153
    24
    Muskegon, MI USA
    Lucifer, the battery isn't all that bad, but I have learned to turn off the dome lights in my '04 Prius. Saved a many a dead battery.
  5. Mendel Leisk
    42,355
    Check the Owners Manual for second gen requirements, but if it's like third gen, you don't want to exceed 4 amp. 3~4 amp is good range. It should be an up-to-date smart charger, the kind that runs through charging cycles, monitors the battery's condition, wrapping up with a very low maintenance charge level, so that it can be left on indefinitely if needed.
    I'd recommend the CTEK 3300, but looking around they seem to be getting rare. There is a CTEK replacement for that one, and several manufacturers in the same field.
    Maybe something like this:
    NOCO Genius G3500 Smart Battery Charger | Canadian Tire
  6. JTM2955
    JTM2955 Active Member
    475
    185
    My 2004 Gen 2 12 volt battery made it almost 10 years. It was still starting the system but my mileage dropped like a stone.
    I let Toyota replace it, since it made it about ten years. Now that was two years ago. My car may get driven everyday or it may sit for three or four days. My mileage is erratic, my belief is the car is charging up the small battery and recharging the HV battery, too. If I drive it daily, my mileage over the entire tank is higher, too.
    LG G3 T-MOBILE phone ☎
  7. Mendel Leisk
    42,355
    I just got a rude awakening: in Canada at least, the stock 3rd gen battery, YUASA S46B24R-GS, is going for $273 (CAN) at the dealership parts departments. I contacted a couple, one's usually higher than the other, but they're both saying $273. A year back they were around $205~$215.
    Last battery I bought was a conventional one for our daughter's Pilot, maybe 6 months back, it was around $150.
    JTM2955 likes this.
  8. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
  9. Mendel Leisk
    42,355
    I'll check that out, thanks. The $ differences start to dwindle tho, when I factor in our 80 cent Canadian dollar plus duty.
    I read global warming, and milder winters, are causing people to stretch battery life, so with battery returns down the cost of new batteries had to climb. Not sure if that makes sense, but it's the story, lol.
    dorunron likes this.
  10. Mendel Leisk
    42,355
    Shipping was $135, from AutoNation. Then there's the dollar conversion and duty.
    Toodle down to local dealership with fistfuls of $'s still cheaper.
