How long until battery dies when parked?
Discussion in 'Prius v Main Forum' started by wstt, Apr 8, 2014.
  1. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    But hot does
  2. GregP507
    GregP507 Senior Member
    3,002
    481
    I say different. How cold does it get in Florida?
  3. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    You can start the Prius hybrid system with a half dozen D-cell batteries.
    No kidding. I live in a area where a battery is expected to die in 3-4 years. Its not from the cold.
    I have to say here that you have exceeded your level of actual knowledge. Heat kills batteries faster than cold does.
  4. GregP507
    3,002
    481
    How does one exceed one's level of knowledge exactly?
    It's not the cold directly, it's the strain it puts on the battery.
  5. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    In 'normal' cars the cold makes the engine oil thick, the transmission lube thick, the diff lube thick, etc.
    None of this matters in a Prius, as the 12 volt battery does not start the engine.
  6. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    Happens on a fairly regular basis, unfortunately.
    #46 Easy Rider 2, Aug 9, 2014
  7. cdrom
    cdrom Junior Member
    27
    While I've not experienced any lengthy shutdown time with my current Prius v Three (Three not III because uppercase Roman numerals were used for model designation year 2010 only) did have occasion with old Gen 2, 2004. In that case was on an extended 28 day trip with car parked at airport (it was also August timeframe). When got back the car started right up and never noticed any problems. This occurred when the Gen 2 was six years old. Don't know if this helps but is from practical experience.
  8. tanasit
    tanasit Member
    399
    60
    Philadelphia
    My previous car used several electric fans in place of the belt driven one. I was happy with the deep cycle battery that last over 6 years while the regular one was about 4 in PA.
    After reading this thread, I checked *bay price for both and guess what: the deep cycle = $147 and the OEM = $170. (price as of today).
    In this case, I'd rather go with the yellow top deep cycle.
  9. fuzzy1
    10,707
    Better add two more to the stack.
  10. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    I think it matters where the voltage readings are taken (engine fuse box vs. battery terminals). There is a difference of about 0.10 - 0.15 v from measuring directly at the battery or the terminals in the engine compartment. That's why I mentioned where the readings were taken.
    You mentioned ideal voltage with "no load". Unless you disconnect the 12v battery to check the voltage, there will always be parasite loads on it.
    "Dangerously" is a bit of an exaggeration in this case since we are not using it to crank the engine. Unless you sit in accessory mode for extended periods, the 12v battery doesn't do a lot of work. Most of the time, it is being charged (maintained) when the majority of the cabin 12v items are drawing from it. Regardless, I don't think the computer would fail to power up at 12.1.
  11. GregP507
    3,002
    481
    There should be no difference in voltage if there is truly no load. The difference is a tell-tale sign of a load somewhere.
  12. hill
    9,038
    Believe it or not - there HAVE been numb skulls that leave ignition on with ICE not running (warmed to stage 4) - car in neutral - walk away, and end up with dead traction packs. The aux battery? cheap in comparison.
  13. GregP507
    3,002
    481
    I've carped about this bitterly in previous threads, but that should never happen. Not that I'd ever want to test it, but there should be some sort of protection that cuts off all battery drain long before the battery is in danger of going dead.
  14. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    Of course, it is part of the car's complex electrical system.
    To quote myself: "Unless you disconnect the 12v battery to check the voltage, there will always be parasite loads on it." :)
  15. GregP507
    3,002
    481
    Many batteries discharge themselves internally as well.
  16. tanasit
    tanasit Member
    399
    60
    Philadelphia
    Honda Hybrid outsold the Prius in several Asian country because the Prius can not set to"N", while parking!
    This is the requirement when you park your car at most shopping malls so that you can park perpendicular in front of the parked cars and when they want to come out, they or the passerby or the security will push your car out of the way.
    This is the normal practice over there. ;)
  17. GregP507
    3,002
    481
    What happens when the terrain isn't level?
  18. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    It most certainly can, but you do need the key to do it. This is no different than any car.
  19. Easy Rider 2
    1,584
    258
    Ocala, FL
    OK let's guess at what he was really trying to say.
    Can you shut off a Prius while the selector is in N......and have it actually shut off........and NOT have the transmission automatically lock ??
    As for uneven terrain, you just apply the parking brake........like you SHOULD be doing all the time anyway.
    If the parking brake is electric and can't be released without the key, that could be a problem too.
  20. tanasit
    tanasit Member
    399
    60
    Philadelphia
    I meant to say parked and left the car unattended then go shopping or whatever.
    They locked the doors and keep the wheels straight with gear in "N" for the reason mentioned.
