How long will my tires last?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by introibo42, Jan 7, 2019.
  1. introibo42
    introibo42 New Member
    Tipp City, OH
    I drive a 2014 Prius Two. In the 14 months since I purchased the vehicle in October 2017, I have added 40,000 miles to it. (My work commute is rather long and also have been on several road trips over the past year). I am based out of a moderate-sized midwestern city and my daily work commute is 98% low-stress interstate cruising. Other, non-work-commute driving is a mix of interstate and city roads. The tires were new when I purchased the car. Michelin. Aside from keeping them filled with air and tire rotations during oil changes, I have had to do no maintenance on the tires since I've owned the car. How many more miles / how much longer do you think the tire life will be?
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    2 years, 3 months, 1 week, 4 days, 3 hours and 25 seconds left on tires.
  3. GrGramps
    GrGramps Active Member
    294
    176
    Western North Carolina
    That number is best calculated by someone who knows the tread depth when the tires were new and the current tread depth. That should allow a good estimate. Anything else would be a guess, and probably a poor one.
    A tread depth gauge is a handy tool to have.
    RMB and padroo like this.
  4. Mendel Leisk
    42,239
    Step one: get a tread depth gauge, measure what you have left.
    Then, look up the new tire tread depth. Decide your mininum tread depth "comfort level", and for this I woudn't cheap out, would say 4/32" bare minimum, more if there's any possibility they'll encounter snow.
    Extrapolate from the above data. Let's say your new tread depth was 10/32", and you currently have 6/32", and your minumum tread will be 4/32". That's a "lfespan" of 6/32", and you've already eaten up 4/32". Then do a ratio equation (overkill but whatever):
    (This example practically falls into your lap.)
  5. padroo
    padroo Senior Member
    2,763
    2,253
    Welcome to Prius Chat.
    You don't want to run those interstates with minimum tread on your tires especially with the amount of driving you do especially on winter roads. There is a lot of good information by others.
    How much do you know about tires? Do you know where the wear bars are on the tires? Look at them, they are there for a visual reference. If you are getting close to them you will have time to start looking for new tires.
    Drive safe.
    Mendel Leisk and RMB like this.
  6. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Too many variables
  7. Siward
    Siward Active Member
    314
    128
    Toronto
    So many variables. Generally you watch for threadwear or tire age rot except for the unexpected tire damage or uneven wear. You will be forced to replace your tires if the unexpected happens. There are many tire articles online:
    Threadwear - Rotate tires to maximize tire thread life
    https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=157
    Tire Rot or Age
    Do You Really Need To Replace Those Tires?
    Uneven wear due to alignment or suspension
    3 Ways to Maintain Better Steering Alignment - Veenstra's Auto Repair
    Punctures that cannot be patched or unrepairable leaks
    (I don't have any hyperlinks)
    How many miles you have left depends on which of the above happens first. Some drivers simply replace them when they subjectively realize the tires are starting to slip or don't get enough traction.
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    At the very least, your tires should have been rotated during that 40,000 miles; probably at least twice.
    Visit a tire store and have them inspected........and ask them to guess at how much you have left.
    Unless they were brand new when you got them, my guess would be that they are close to needing replacement NOW.
  9. Mendel Leisk
    42,239
    ^ Yeah our OEM tires had plenty of tread left, but were nearing 10 years from manufacture date (there's a code stamped on side wall), and were getting pretty cracked, and a couple of "weird" bits: a short, zigzag split in between the tread on one, and an odd hole, not all the way through, on another. It was time, lol.
    Plus, one was plug-repaired, though that didn't worry me.
    #9 Mendel Leisk, Jan 8, 2019
  10. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    449
    186
    Indiana
    2022 Prius Prime
    impossible to say. However I will suggest that you can further the life of your tires by rotating more often, if you are only rotating with oil changes every 10k (assuming you follow factory schedule) you can probably extend life by doing every 5k. Proper inflation helps as well. Other than that it just all depends on your specific situation. I drive about 75% interstate on my daily commute of 42 miles each way, and I got 60K out of the factory Bridgestone Ecopia tires. Could have gotten more but ended up changing them due to winter approaching and wanting to be safe. Had it been summer I could have easily gotten another 5 to 7k easily out out of them.
  11. bisco
    52,751
    i can't believe no other maintenance has been done to the tires except pressure checks and rotation (n)
    Grit likes this.
  12. tonynap
    tonynap Member
    43
    38
    NY
    I do all highway driving and have gotten 65k out of each set of tires which, coincidentally, is close to the tread life warranty. Inflate and rotate.
