How low is too low?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by swaggingprius, Nov 7, 2011.
  1. macmaster05
    macmaster05 Senor Member
    4,050
    730
    There are actually no such thing as aggressive wheels. Rather, there are aggressive stances, that's qualities include lots of negative camber, virtually no wheel gap and tire sidewall, and slammed or flush wheels.
    You have coilovers already, so if you really want an aggressive stance, I'd say half of your work is done. You'll need bigger and wider rims and narrower tire sidewalls, and possibly spacers if the rim offsets are too high.
    But based on your thread that you're already rubbing, I'd take a guess that you actaully don't want an aggressive stance.
  2. andino
    andino Senior Member
    746
    551
    San Jose, CA
    You'll have to do a lot more than just aggressive wheels (size, offset, width) to have an aggressive stance. There's a lot of factors that have to come together for it to work. Camber, height, tire stretch, fender rolling/pulling etc to get that look.
    That being said, it can be done on a prius however the problem I ran into on my quest (hence why nothing has progressed in the stance department) is the rear has no adjustments for camber, toe, etc so it makes for awkward looking stance. The rear gains positive camber as you go lower whereas the front gains negative. More positive camber (without being able to adjust) means you have to compensate by running a higher offset or pulling of fender (assuming fenders are rolled flat already).
    Also its kinda of hard to do with a 5axis front lip since that lip has such low front corners. They're significantly lower than the center of the lip making angling over bumps and into driveways especially difficult if you're static (on coilovers) vs on air.
    I've gotten away with 18x9.5 +38 up front and +33 in rear with 225/40/18 stretched all round. That's without any fender work. BUT I'm only on htechs at the moment so when I go lower, there will need to be adjustments in my wheel specs (and wheels since I want different ones)
  3. swaggingprius
    swaggingprius Member
    88
    29
    East Coast
    So, my car is out of the shop. It turns out it was rubbing only the inner fender liner on the driver's side. They cranked it up a bit. It helped but it is not 100%, still some minor rub incidents when doing over 80 and road gets bumpy. Once the springs settle, I will bring it back for readjustment.
    I had a long winded conversation with the crew about wheels last night. Ideas tossed around such as staggered look with 18x9 rear while keeping 18x8 front and other variations. So, there is a lot that can be done, but for me it will not happen just yet.
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Good to hear it's basically fixed.
    Keep in mind that the wider you go with the wheels the lower your mpg will be. Physics sucks! You also will not be able to rotate the tires front to rear. IMO keep the same size wheels on front and rear. You're not driving a Porsche or Corvette.
  5. andino
    746
    551
    San Jose, CA
    I totally agree on running non-stagger but it looks so good! If anything though, I guess you could run a spacer in back to get the rim flush to the fender if that's what you're aiming for.
  6. Superdrol
    Superdrol Member
    399
    32
    This dEpends on how wide you are running the tires. I'd give atleast a 1.5-2" gap because if the tires are wide you may be actually rubbing against the strut base from inside.
    I lowered my Camry about 5.75" from stock when I owned it and hitting bumps I'd rub the tire against the strut base. One thing you might want to keep in mind and I'd caution this for anyone wanting to lower their car excessively, your front CV joints are constantly operating at a steep angle. This is different than your alignment.
    The alignment adjust the center of the tire but the CV joint is still operating steeply angled beyond what they were manufactured for. My Camry eventually had to have both front end half shafts replaced because of this so keep it in mind.
  7. Superdrol
    Superdrol Member
    399
    32
    Make sure you are adjusting the alignment everytime you are raising it lowering your car. You will bald the edges of your tires if you don't keep the alignment straight.
    After owning once the adjustible struts and coil overs I've just stuck to 2.5" drop straight springs. They are just plugged in and lower just enough. I also had problems with vibration so I'd frequently check the lock rings to make sure they were tightly fitted.
  8. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    Oh, it ain't too low ... if you want to damage your undercarriage.:rolleyes:
  9. swaggingprius
    88
    29
    East Coast
    Today I learned that it is too low for car wash. It will not clear the track.
  10. Superdrol
    Superdrol Member
    399
    32
    With the lip you may need to raise it a bit. Judging by your pictures, I'd lift the car about minimum 2-2.5" from the top of the wheel to the top of the fender. Or basically the diameter of a soda can on top.
    Slamming the car to the ground like you have looks really good no question. But driving a car that sits that low for a daily driver is not practical.
    Bring it up a few inches and make it practical. In the long term you'll be happier. Plus you are not stressing your CV joint as much.
  11. Superdrol
    Superdrol Member
    399
    32
    For most cars lowering the car any more than 2-2.5" from stock settings creates issues in the long run. Having it set like that as a show car is one thing. Driving a slammed car as a daily driver is another.
  12. swaggingprius
    88
    29
    East Coast
    I certainly learned a lesson in practicality this weekend, since it took me about 5 car wash places before finding the that kind'a sord'a had a track low enough. Then in terms of appeal, even the owner of the place came out and took pictures of what he thought is "the most gangster looking Prius."
    With all this, I did request only 1 inch drop from stock, but from your comments it seems they went a lot further. I will look into it.
    Thanks!
  13. swaggingprius
    88
    29
    East Coast
    More about riding low. So, last night I come back to my car after 12hrs at work, only to discover the parking lights on. :eek:
    So, obviously I did something wrong or different when rushing and leaving the car. In the mornings, I typically drive with the lights on and leave them on when turning the car off. I mean, it does have autoshut off, right?
    Well, this time it did not.
    Long story short, I was worried that it might need tow due to a wild and crazy electrical malfunction and everything being short circuit. Fortunately, only the battery needed recharging.
    My concern was getting the car on the tow, even the ones with a platform, yanking the car from behind puts it at a very steep incline and of course damaging the front lip.
    Question for other low riders that have some type of front lip. Have you ever been towed? If so, what did you do to minimize or avoid damage to your aerokits?
    Peace
  14. Duckles McGee
    Duckles McGee Junior Member
    95
    Oaks, PA
    Now way to do it unless you request a flatbed.
    I've only had an issue a few times in the past and the tow truck driver fortunately had planks to ramp the car up.
    As for the rubbing, you might need to roll the fenders. Not for the feint at heart, but if you want to go low, that's the way to go. Or change your wheel/ tire setup.
    This was my lowest static car, before putting it on air ride (where it parked on the ground.) The subframe in this picture is about 1" off the ground, never really hit the front lip, but I had no chance of clearing speed bumps.
    In my experience, other issues you will have:
    * Getting onto alignment racks
    * Getting a jack underneath the car (drive the car onto 2x4's)
    * Dead animals.
  15. swaggingprius
    88
    29
    East Coast
    hahahahahahahaaaaaaaaaaaaa!
  16. NineScorpions
    NineScorpions Economy, Meet Style!!
    375
    64
    From the pics...the front looked just a tic lower and sounds like that was your "free" fix. Apparently you never have to go toe to toe with speed bumps where you live :rolleyes: I do not have that luxury.
  17. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Auto shutoff will not work if you mess with the control after powering down. For example, if after you powered down, you turn the headlights off then back on remembering that auto shutoff will take care of it it won't work at all.
  18. BayAreaPrius11
    BayAreaPrius11 New Member
    17
    SF Bay Area
  19. El Dobro
    El Dobro A Member
    7,076
    3,258
    I can always tell when my next door neighbor's daughter has a new boyfriend. I hear them slam into his driveway when they come to pick her up. It usually only happens once per boyfriend, unlesss she gets a stupid one.
  20. NineScorpions
    375
    64
    That video is why I see a lot of extremely lowered cars with the body kits beat to crap and paint missing. If you are going that low...better pack airbags or hydrolics so you can get the bloody thing off the pavement when you actually need to drive. But none of that sounds like talk for a Pri.
