How Many Amps at 120V
Discussion in 'Prime Plug-in Charging' started by mr88cet, Jan 29, 2017.
  1. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    Yes, I also saw mention of that in one of the YouTube videos on the P.Prime, but yes, thanks for mentioning it. Might also be of use if you have other stuff on the circuit, although it's clearly preferable to charge on a dedicated circuit.
  2. bwilson4web
    16,552
    We have two metrics that indicate the Prime charger may be briefly cycling ON/OFF during the charging:
    Two hypothesis come to mind:
    • checking the unloaded battery pack voltage
    • thermal, the charger gets too hot and has to cool
    The first one, no problem although it is a little kludgie. The second one would cause me concern as that means trouble in the Alabama summer heat. Anyone have some insights?
  3. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    I would guess this is battery pack checking of one sort or another. It definitely isn't cooling as it's off for too short a time.
    priuscatprimeguy likes this.
  4. bwilson4web
    16,552
    It does look like a 15 minute interval.
  5. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    The PIP had the same results
  6. priuscatprimeguy
    2,730
    2,640
    if it was a fifteen minute interval then 15 minutes times 16 intervals equals an extra 4 hours to the charging interval so it's highly unlikely that it's 15 minutes.update: oops ok, you mean every fifteen minutes, that makes more sense:D
  7. William Redoubt
    William Redoubt Senior Member
    1,228
    1,174
    Coronado Island, California
    Good plan on the 30 amp sub panel.
    Utilities are concerned about wave form pollution back feeding into their system. Harmonics from utility customers are reflected onto the utility grid and accumulate as customers add more modern electronics, like the non-linear loads from charging stations. Because harmonics can result in higher maintenance costs to the utility, financial penalties for lack of compliance with a utility's harmonic limits are very common for industrial and commercial customers. These penalties are significant, and therefore most commercial and industrial customers install equipment to condition the back feeding of such anomalies into the grid. I doubt such measures are present in electric car chargers, but given a significant installation base, they may be necessary or customers may face penalties for violations.
