How many amps used from 12v battery?
Discussion in 'Gen 2 Prius Technical Discussion' started by CassieFordham, Sep 13, 2016.
  1. CassieFordham
    CassieFordham New Member
    I've been trying to find out how many amps are used under different conditions, but I haven't been successful in my searches
    What are the minimum/maximum amps are used:
    when the car is off?
    when the cabin light is left on?
    when start button has been pressed once,
    when start button has been pressed twice, without pressing the brake pedal?
    when start button has been pressed twice, pressing the brake pedal?
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    From what I understand the 12v battery is used to boot up the main ECU. After that the HV battery does the majority, if not all, the battery duties. This is one of the reasons why CCA ratings don't mean squat to a Prius.
  3. ChapmanF
    19,061
    Seems like the OP had more specific questions in mind. I know there has been plenty of past discussion ... my sense was that the load when the car is off might be somewhere around 30 mA. With the interior lights left on, probably somewhere in the neighborhood of an amp (I have not measured this, I'm just estimating based on the idea of one or two several-watt dome light bulbs).
    When the start button is pressed once, foot off brake (ACC mode): haven't measured, would guess several amps (depending on how loudly you're playing the radio).
    Start button pressed twice (foot off brake - IG ON mode): I haven't measured, I'm thinking tens of amps (again depending on what you've turned on, you might near 100 if you have window defoggers, wipers, seat heaters, and heater blower all cranked up).
    Start button pressed twice, pressing the brake pedal: is this a trick question? :)
    Start button pressed, pressing the brake pedal (READY ON mode): I think it's been reported to peak around 30 amps briefly, just until the main relays and the hybrid system come on line in a split second; after that the current flow is into the 12 volt battery, because the DC/DC converter has taken over supplying it. The charging current (into the battery) is not supposed to exceed about 5 amps.
    To find other threads that may have more definitive, measured information, you probably can search here on PriusChat a little harder, and also don't overlook hobbit's many Prius links.
    -Chap
  4. CassieFordham
    Thank you for taking the time to answer my questions, (the last one was not a trick question I was lookng for the kind of answer you gave).
    I've provably spent 20 hours or more trying to search for the actual numbers, search engines are only useful if you know how to phrase your search parameters (garbage in garbage out) so darI haven't come upon the magic formula to get the real numbers . If you don't have the numbers, then even some guidance on what to search for would be greatly appreciated
    IMkenNY likes this.
  5. ChapmanF
    19,061
    Well, if it's Prius technical information you're looking for, sooner or later you're going to know hobbit's site inside and out.
    You might start with his 12 volt battery page, and his tech training page at the sections for "Startup" and "12V currents".
    Each of those sections shows a scope trace, so you get a good qualitative idea, though it's funny I never noticed before the vertical scales are both unlabeled. (Or rather, the second one has the scale labeled 50 mV, so he was apparently measuring across a shunt or using a Hall-effect clamp, but I don't see those details in the page for you to get from the scope's millivolts back to amps.)
    I notice he measured the resting current of his Gen 2 (without smartkey) at around 11ish milliamps. That's lower than I've ever measured my Gen 3, I think I was seeing around 30 mA even with smartkey off.
    You could take some measurements yourself and add to the body of knowledge ... you can probably also get the volts-to-amps relationship for hobbit's scope traces if you communicate with him. (Maybe that training page is just a summary and he has more detailed pages for the various sections ... I haven't found them just poking around this morning, but that doesn't mean they're not there.)
    -Chap
  6. tallman
    tallman Junior Member
    60
    wv
    Thinking my 2007 has a high amp draw at 10.5 amps just hitting the button twice with foot off the brake no access on ,the hv relays getting 11 volts and won't kick in
  7. davecook89t
    davecook89t Senior Member
    1,093
    832
    Washington State, Florida
    You might try pulling different fuses to find which circuit is shorting out, probably starting with the Dome Light Fuse, since many of the accessories draw their power through it.
    Gen2-Dome Light fuse | PriusChat
  8. davecook89t
    1,093
    832
    Actually, before you even start thinking about accessories that might be drawing down your power, though, you would be better off checking the fusible link that @TMR-JWAP pointed you towards in your other post.
    Low voltage to traction battery relays. (11.2) , inverter pump doesn't run | PriusChat
  9. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    Yes.....check the fusible link....or just pull the two abs relays.
    Otherwise you're going to drain the 12v battery pretty quick if you leave the car powered up.
    or you'll burn up whatever is drawing that 10 amp load..i haven't really dug into that yet, but since it's the abs system pulling the current, my initial guess would be the abs pump trying to run because it's lost it's ecu sensors or something.
    davecook89t likes this.
  10. dolj
    dolj Senior Member
    8,657
    4,407
    Wellington, New Zealand
    It is not a great idea to be posting about the same problem in two (or more) different threads. Pick one and use only that one.
