How many dead cells will keep a Prius from starting?
Discussion in 'Gen 2 Prius Main Forum' started by skittle021, Apr 9, 2021.
  1. skittle021
    skittle021 New Member
    16
    Mississippi
    I've got a 2005 Prius that refuses to start up no matter what. I've replaced the 12V battery, but still nothing. I have now been greeted by the infamous red triangle and a "main battery" logo on the touch screen.
    I removed my hybrid battery and tested the cells with a multimeter. 4 cells only register between 2.3v and 3.5v. The rest all measure a minimum of 7.39, most are around 7.5v.
    My question is: will 4 dead cells prevent the car from starting? It seems like more would have to die before the car would lock itself down like this. Is there anything else I should check or is it time to just order some new cells or a new battery?
  2. ozmatt
    ozmatt Active Member
    637
    263
    Australia
    Hi how's it going :)
    Absolutely it will, even one cell could prevent it from "ready" if it's leaking electrolyte which it sounds like yours is, take a look at the underside they leak at the thread on bottom.
    Hv leak will disable the car
    Matt
    52,640
    the battery wil not work when the voltage drops below the computers parameters.
    that being said, your best course of action would be to read the trouble codes, hopefully avoiding a wild goose chase
  4. PriusCamper
    PriusCamper Senior Member
    13,301
    5,377
    Pacific Northwest, USA
    And its not just the goose that chase too... Happens with ducks as well...
  5. ozmatt
    637
    263
    Australia
    I notice when there's a bunch of modules in the 2,3&4v range (usually next to each other) it's a good indication of a car that's been driven for a very long time on a bad battery, it doesn't generally happen over night! and probably has leakers and burnt up ecu and wiring harness.. all the good stuff.
    Never get many good modules out of these packs, if this is the case might be easier to find another pack!
