How many gallons does the Prius C hold?
Discussion in 'Prius c Main Forum' started by Ardentauthor, Jan 28, 2013.
  1. Ardentauthor
    Ardentauthor New Member
    At a bit less than half empty, it took 5.7 gallons to fill completely. How many gallons can the tank hold?
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    9.5 gallons
    Toyota Prius c - 2012 Performance & Specifications
    WEIGHTS AND CAPACITIES
    Curb weight (lb.)
    2500​
    2500​
    2500​
    2500​
    Seating capacity
    5​
    5​
    5​
    5​
    Passenger volume (cu. ft.)
    87.4​
    87.4​
    87.4​
    87.4​
    Cargo volume [4] (cu.ft.)
    17.1​
    17.1​
    17.1​
    17.1​
    Fuel tank (gal.)
    9.5​
    9.5​
    9.5​
    9.5​
    RocMills likes this.
  3. Ardentauthor
  4. ufourya
    ufourya We the People
    1,258
    336
    42
    Some added information you might find interesting:
    When the last pip on your fuel gauge starts blinking, there is still a little over one gallon in the tank. I think the manual states 1.2 . It is also known that the manufacturing processes allow for some slight differences in tank volume from car to car of the same model. It is also possible to fill beyond what the tank nominally holds by filling up to the brim of the filler tube. (This is not recommended.)
  5. james cook
    james cook Member
    145
    36
    Louisiana
    goes empty at 7.5-8.7
  6. ufourya
    1,258
    336
    42
    There is a difference between 'goes empty' and 'I put gas in when the last pip flashes and it has taken between 7.5 and 8.7 gallons,' or whatever else you base the 'goes empty' on. Empty means there is no more fuel in the tank. Just sayin'.
  7. Brad K
    Brad K Member
    168
    53
    tank holds 9.5 gallons they say. fuel gauge flashes empty at 1.5 gallons left in tank. I have put 9.6 gallons in the tank before so I assume it hold more than 9.5 gallons in reality, not sure how much more.
  8. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    Owners manual states 9.5. Production variances can change a bit, but not a lot. If you're putting in more than 9.5, it's going into the lines, the filler neck, or the carbon canister.
