How many Gen 1's still in day to day use?
Discussion in 'Generation 1 Prius Discussion' started by pshawfocus, Nov 11, 2018.
  1. Mark6868
    Mark6868 Active Member
    118
    131
    London
    2001 Prius
    Mine's the same. Looks brand new inside and out, and everything still works as it should. I get well over 55 mpg regularly. Often more. Only £20 per year road tax. Very comfortable on a long journey.
  2. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    All very valid points, some of which I alluded in my last paragraph. If you are happy to accept all of that and know that a repair done in that way will last 6 months to a year (maybe two, if it was done extremely well) then that is all good, and reasonable even. I wasn't questioning the rationale.
    I was simply making the point you cannot compare the repair you had done to a full replacement with new modules which is for what you would pay Toyota. Therefore the £400 vs £1700 comparison is irrelevant and disingenuous, even.
    #22 dolj, Feb 15, 2019
  3. Mark6868
    118
    131
    London
    2001 Prius
    Okay thank you.
  4. ArcticDragon
    ArcticDragon Junior Member
    Olympia
    2002 Prius
    I have a 2002 with 260,000 miles on it. the only thing that i need to do with it is to replace valve cover gasket and lower o2 sensor other then that car runs awesomely. I see about 6 daily in just Olympia WA alone.
    andif anyone can help on a good and better way to take valve cover off i am all ears
    Prodigyplace and bisco like this.
  5. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    We have 3 in my family alone :)
    Prodigyplace and Raytheeagle like this.
  6. czunit
    czunit Junior Member
    29
    baltimore MD
    2001 Prius
    I think there was a massive drop-off on the Gen 1's once the batteries started to die. Replacement was very expensive and as a result most people dumped them. The ones on the road now have had the batteries replaced (including mine) and my guess is the next culling happens at around 200k miles when the catalytic converters start throwing errors.
    Note I fixed my P0420 errors by replacing the ignition coils, they seem to be a wear item by 180k miles. Wonder what the next wear item will be. Aside from the keys.....
    210k miles on 2001 Prius.
  7. Roger Ritchie
    Roger Ritchie Junior Member
    Louisville KY
    2003 Prius
    Picked up a 2003 with a bad HV battery for a song, and rebuilt the pack with Gen 2 modules. Three days on the road and all is well. The AC blows cold, and everything works. 230,000 miles. This will be my daily driver, and a stable mate for our Gen 3. 20190618_192035.jpg
    telmo744 and WHCSC like this.
  8. 2002_Pri_Rod
    2002_Pri_Rod Member
    92
    69
    Forestville, CA
    2002 Prius
    I think about this thread almost daily as I tend to see 3 to 4 Gen 1s on my daily 60 mile commute here in the north bay - today I saw two gen 1s, many many gen 2s and 3, a honda clarion, two Tesla model S's, two or three fusion hybrids etc and I was not even paying attention
    WHCSC and Raytheeagle like this.
  9. ronlewis
    ronlewis Active Member
    986
    196
    texas
    2001 Prius
    I have 6 of them, but only two are running today. I hope to two others back on the road with parts from the other two. That's why I'm hear trying to get started. I've owned a First Gen continuously since 2001. Put 180k on that one. I think the ones I have now all have under 100k except one of the part cars, but I'd have to check again. I bought several of them a couple of years ago and haven't had time to mess with them. Going to give one each to my son and daughter, keep one myself, and maybe sell one.
    Anyone know where to get a shop manual? You'd think there'd be a lot of used ones. I haven't really looked yet though.
  10. ronlewis
    986
    196
    texas
    2001 Prius
    Had someone hit one of my Gen 1s last year. Their insurance totaled it and gave me $3900. I bought it back for $250 and then bought a parts car from the Houston hurricane for a couple of hundred bucks that has all the parts I need to fix the front fender, hood, bumper cover and apron.
  11. 2002_Pri_Rod
    2002_Pri_Rod Member
    92
    69
    Forestville, CA
    2002 Prius
    Very cool - good luck - I have two first gens now and have thought about buying broke down ones and fixing them but work, money, and other projects keep getting higher priority
    About the manuals I bought a set of hardcopy shop manuals a couple of years ago off Ebay- Brian in Tucson and some others have mentioned have mentioned there are pdf versions also but I have never checked it out
    Raytheeagle likes this.
  12. Prodigyplace
    12,570
    11,782
    Central Virginia
    Perhaps @Brian in Tucson could share links?
  13. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    Brian in Tucson says that they are available from Rock auto. He also has a set of hard copies for an 02 that he would sell for $100, nice shape from Toyota. Includes shipping.
    WHCSC and Prodigyplace like this.
