How Many kWh in a Full Charge?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bilofsky, Jan 2, 2013.
  1. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    Just to be clear here, are you in HV mode at this point? Do you have the segmented battery icon? I do. When it switches to HV mode, I have 6 battery segments visible and SoC is at 23.1%. When it gets down to 2 battery bar segments, SOC is at 18% and the ICE automatically comes on and stays on until 4 battery segments are visible again (I don't recall what the SOC was at that point). At that point the ICE will shutdown again if it is not needed.
    Are sure you aren't looking at minimum SOC? I know you said you and I have same exact Xgauge programmed.
    lensovet likes this.
  2. bilofsky
    bilofsky Privolting Member
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    Maybe we're confusing two trigger points. At SoC 21 or so, the PiP switches from EV mode into HV mode. But if pushed gently it can still run in EV under HV mode with the ICE off until it gets to a lower SoC in the teens, at which point the ICE is forced on.
    Not for me, at the moment. I'm seeing an SoC around 33 before a charge up to the 80's after. But SoC (all) is still down in the 17's. What gives?
    I added displays for the battery blocks to my Torque screen. Looks like up to bank 08 makes sens, but after that the numbers are weird. Are there 8 battery blocks?
  3. devprius
    devprius /dev/geek
    979
    291
    For me, SoC of 23.1% is where it switches from EV to HV mode. I can run in stealth mode (EV at slow speeds while in HV mode) all the way down to 18%, at which point the ICE is forced to come on.
    I suspect some sort of subtle math error is going on here. I just don't know if the Scan Gauge is at fault or the Torque app. Or both. I'm tempted to pickup a cheap Android handset/tablet and get a bluetooth OBDII dongle and play with Torque.
  4. John H
    John H Senior Member
    2,208
    558
    at that point, is the distance traveled added to HV or EV ?
  5. devprius
    devprius /dev/geek
    979
    291
    Ooooooh, good question. I'll have to try to setup an experiment to test that...
  6. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    According to the spreadsheet that I think you and I are referring to, I am using State of Charge. Not minimum state of charge. And no my vehicle is still in EV mode. It is segmented and I am creeping along at 20 mph.
    The prius looks at what are the battery demands. If you are pulling too many watts it will switch to HV much sooner.
  7. lensovet
    2,615
    496
    Burlington, NJ
    Pretty sure EV miles are only counted when you're in EV mode and the EV car is showing. EV-boost, engine running with no gas in EV, as well as golf cart mode in HV all don't count.
  8. devprius
    devprius /dev/geek
    979
    291
    I'm well aware of how the system works. But it's important to make a distinction between EV abilities available in HV mode (aka stealth mode), and true EV mode. True EV mode is when you have the green EV light on the dash, and the HSI screen shows a single icon of a car with the letters EV in it. HV mode is when the green EV light goes out, the HSI screen changes to show two icons, one with a smaller outline of a car that may or not have the EV letters, and the other with the letters ECO in it.
    For me, the Scan Gauge shows that the SOC is 23.1% when it switches from true EV mode to HV mode. I can use EV capabilities at this point all the way down to SOC of 18% if I'm light footed enough, at which point the ICE comes on. I'm still in HV mode even though I'm using EV capabilities. That's the point I'm trying to make. It sounds like you are stating that you can be in HV mode, but use EV capabilities all the way down to 14.3% before the ICE is forced to come on.
  9. devprius
    devprius /dev/geek
    979
    291
    Looks like it's added to the HV miles. I did a couple of loops around the campus. 2 miles, totally flat, no ICE usage, about 25 MPH. EV miles stayed the same, HV miles went up.
    Redpoint5 and John H like this.
  10. devprius
    devprius /dev/geek
    979
    291
    Ayup as I confirmed at lunch today. EV miles only counted if in EV mode with the EV car showing. Anything else, even if it's stealth EV in HV mode, gets added the HV column.
  11. John H
    2,208
    558
    That creates a bit of a challenge for computing the EV only kWh/100 miles.
  12. 3PriusMike
    3,101
    2,419
    Silicon Valley
    No, not really. Once you are in HV mode all your energy is coming from gas. Yes, the battery level goes up and down a bit, but the car tends to want it to even out. It will use a little, then charge a little. Every time you use a little (i.e. stealth mode) you don't really want it counting towards EV miles...not really an accurate accounting.
    Mike
  13. chesleyn
    596
    158
    Los Angeles
    14.3 was a typo. Sorry. 24.3% soc is the minimum before ICE kicks on (HV mode). I have never taken the soc lower than 20% in HV mode.
    And devprius, you are right, you can sometimes nurse it down to 23.1% soc before the switchover, but you have to be driving very slow.
  14. devprius
    devprius /dev/geek
    979
    291
    I think you might have a E where F should be in your MTH function in the Scan Gauge's X-gauge programming for SoC. That might explain our different readings.
  15. devprius
    devprius /dev/geek
    979
    291
    I finally had the time to measure the actual charging losses at 240V and 120V:
    At 240V, the charging loss is approximately 16% to 17%. I measured 2.3 kW being drawn from the wall (well, seen at my utility's smart meter). The PiP's MID indicated that 1.9 kW was flowing into the battery. The Scan Gauge showed 9.3 Amps flowing into the battery. 9.3 * 207 (nominal voltage of the battery pack) equals 1925 watts which closely matches what the MID said. 1925 / 2300 = 0.83695652. Call it 0.837 or about 16.3%.
    At 120V, the charging loss is a whopping 30% to 33%. I measured 12.67 amps from the wall (via a clamp-on ammeter), and 121 volts. This is 1533 kW. The MID said 1.0 kW was flowing into the battery, and the Scan Gauge showed 4.9 amps * 207 volts for 1014 watts, which again closes matches what the MID said. 1014 / 1533 = 0.66144814. Call it 0.661. or about 33.9%. Even if if the ammeter was off by 5% and the actual amps were just 12, 12 * 121 = 1452 watts. 1014 / 1452 = 0.69834711. Call it 0.698 or about 30.1%. Still rather large. Ouch.
    SoC was around 28% when I started this experiment. The numbers could be different when the battery is starting to get full (at the end of the charging cycle). I'll try to setup that experiment later this week.
    This should make it a little easier to measure how usable kWh we can get out of the pack.
    Tracksyde, lensovet and Jeff N like this.
  16. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
  17. 3PriusMike
    3,101
    2,419
    Silicon Valley
    Your measurements are far off from the methodology I used...I measured total kWh input and compared to total kwh the EV ratio screen reports consumed. I found a 9% difference.
    If in fact the losses were closer to 30% then when I charged with 3 kwh the battery only got 2.1 kwh and if I drove 14 miles that would mean about 150 wh per mile. Something just doesn't seem right.
    Mike
  18. John H
    2,208
    558
    With the PiP "On" during this actively monitored charging session, you may be adding another 200-300W load to the picture that would not normally be there in an unattended charging session.
  19. chesleyn
    596
    158
    Los Angeles
    Correct calculations. I've charged at many chargepoint locations, and their iphone app tells you how many kWs are being pulled from the station. It's usually 2.2 or 2.3 kW and as you stated the car only displays 1.9kW.
  20. devprius
    devprius /dev/geek
    979
    291
    I wouldn't trust the EV/HV ratio screen to give you an accurate picture of the kWh consumed. We already know that the display truncates values. I.e 3 kWh display might mean 3.1 kWh, or it could mean 3.9 kWh.
